C++ 算法 is_partitioned()函数
C++ 算法 is_partitioned() 用于根据谓词测试指定的范围 [first, last) 是否已被分隔。换句话说,范围内满足谓词的所有元素位于序列的开头。
如果范围为空,则返回 true。
template <class InputIterator, class UnaryPredicate>
bool is_partitioned (InputIterator first, InputIterator last, UnaryPredicate pred);
first :指向范围中第一个元素的输入迭代器。
last :指向范围末尾后一个元素的输入迭代器。
pred :用户定义的一元谓词函数,对于在范围开头预期出现的元素返回true。
如果范围为空或由给定的谓词pred分隔,则此函数返回true,否则返回false。
复杂度
复杂度与范围[first,last)线性相关:对于每个元素调用pred,直到发现不匹配。
数据竞争
访问范围[first,last)中的对象。
每个元素仅被访问一次。
异常
如果pred或迭代器上的操作引发异常,则此函数会引发异常。
请注意,无效的参数会导致未定义的行为。
我们来看一个简单的示例,演示is_partitioned()的用法:
#include <vector>
#include <algorithm>
vector<int> v = {1, 2, 3, 4, 5};
cout<<"Before Partition: ";
for_each(v.begin(), v.end(), [](int v) {
cout << v << " ";
auto pred = [](int x) { return x % 2 == 0; };
// Divide it into an even group and an odd group
partition(v.begin(), v.end(), pred);
cout<<"\nAfter partition : ";
for_each(v.begin(), v.end(), [](int x) {
cout << x << " ";
cout<<"\n\nIs it partitioned?"<<endl;
// Is it divided into an even group and an odd group?
if (is_partitioned(v.begin(), v.end(), pred)) {
cout << "Yes,It is Partitioned" << endl;
else {
cout << "No,It is not Partitioned" << endl;
Before Partition: 1 2 3 4 5
After partition : 4 2 3 1 5
Is it partitioned?
让我们看另一个简单的示例:
#include <vector>
// Defining the BinaryFunction
bool pred(int a)
return (a % 2 == 0);
// Declaring first vector
vector<int> v1 = { 2, 4, 6, 3, 5, 7, 9 };
// Using std::is_partitioned
bool b = std::is_partitioned(v1.begin(), v1.end(), pred);
if (b == 1) {
cout << "All the even no. are present before odd no.";
} else {
cout << "All the even no. are not present before odd no.";
// Inserting an even no. at the end of v1
// so std::is_partitioned returns false
v1.push_back(16);
// Now again using std::is_partitioned
if (b == 1) {
cout << "\nAll the even no. are present before odd no.";
} else {
cout << "\nAll the even no. are not present before odd no.";
让我们看另一个简单的示例:
#include <array>
std::array<int, 9> v = { 1, 2, 3, 4, 5, 6, 7, 8, 9 };
auto is_even = [](int i){ return i % 2 == 0; };
std::cout.setf(std::ios_base::boolalpha);
std::cout << std::is_partitioned(v.begin(), v.end(), is_even) << ' ';
std::partition(v.begin(), v.end(), is_even);
std::reverse(v.begin(), v.end());
std::cout << std::is_partitioned(v.begin(), v.end(), is_even);
false true false
示例4
让我们看另一个简单的示例:
#include <vector>
vector<int> v = {11, 2, 3, 4, 15, 12};
cout << v << " ";
auto pred = [](int x) { return x < 10; };
cout<<"\nAfter partition: ";
cout << x << " ";
cout << "Yes, It is Partitioned." << endl;
else {
cout << "No, It is not Partitioned." << endl;
Before Partition: 11 2 3 4 15 12
After partition: 4 2 3 11 15 12
Is it partitioned?
