C++ 循环队列和优先队列的区别
循环队列和优先队列都遵循队列的机制,可以是线性或循环队列形式。循环队列具有先入先出的功能,而优先队列则按照优先级最高的元素先被服务。
| 圆形队列 | 优先级队列 |
| 元素可以以O(1)的时间插入。 | 执行删除、显示和插入操作。 |
| 它是以循环的方式而不是线性类型的队列数据结构。 | 插入或删除是基于分配的优先级。 |
| 需要较少的内存。 | 优先级队列需要更多的内存。 |
圆形队列C++代码
// Here we are writing down the simple C++ programming language code to
// demonstrate the concept of the Difference between Circular Queue and Priority
// Queue with their relevant code supported by comments and their output
#include
// the below code snippet creates the class of Queue for us where we can
// then perform operations such as insertion, deletion and display later.
class Queue
// the small code snippet helps us with initialising the front and the rear
int rear, front;
// creating the circular queue from here onwards
int size;
int *arr;
public:
Queue(int s)
front = rear = -1;
size = s;
arr = new int[s];
// void, int functions to work with circular queue
void enQueue(int value);
int deQueue();
void displayQueue();
// as we have created a class, it is time to write code to implement the queue
void Queue::enQueue(int value)
if ((front == 0 && rear == size-1) ||
(rear == (front-1)%(size-1)))
printf("\nHey! coder the circular queue is full!");
return;
else if (front == -1)
// it helps us with implementing the first element in the queue for us
front = rear = 0;
arr[rear] = value;
else if (rear == size-1 && front != 0)
rear = 0;
arr[rear] = value;
else
rear++;
arr[rear] = value;
// Function to delete element from Circular Queue
int Queue::deQueue()
// the below code snippet helps us with the deletion operation of the
// circular queue for us.
if (front == -1)
printf("\nthe queue is empty coder");
return INT_MIN;
// writing down the edge cases to be handled
int data = arr[front];
arr[front] = -1;
if (front == rear)
front = -1;
rear = -1;
else if (front == size-1)
front = 0;
else
front++;
return data;
// the below code functionality helps us display the elements of the circular queue we created above.
void Queue::displayQueue()
if (front == -1)
return;
printf("\nthe elements in the circular queue created by us are: ");
if (rear >= front)
for (int i = front; i <= rear; i++)
printf("%d ",arr[i]);
else
for (int i = front; i < size; i++)
printf("%d ", arr[i]);
for (int i = 0; i <= rear; i++)
// this is the int main() driver codee functionality of our C++ program
Queue q(5);
// these are the small code snippet which helps us with pushing the
// elements into our priority queues.
q.enQueue(46);
q.enQueue(3566);
q.enQueue(68);
q.enQueue(-990);
// calling the function written above, which helps us with displaying!
q.displayQueue();
// as we wrote a function body which helps us with deleting the elements
// of the circular queue, it is the time to call them.
printf("\nthe deleted value is = %d", q.deQueue());
q.displayQueue();
q.enQueue(3566);
q.enQueue(768);
q.enQueue(-990);
q.displayQueue();
q.enQueue(46);
/tmp/U6DBXIRSlF.o
the elements in the circular queue created by us are: 46 3566 68 -990
the deleted value is = 46
the deleted value is = 3566
the elements in the circular queue created by us are: 68 -990
the elements in the circular queue created by us are: 68 -990 3566 768 -990
Hey! Coder, the circular queue is full!
现在,循环队列的时间复杂度部分,enQueue()和deQueue()操作的时间复杂度几乎为O(1),因为在任何操作中都没有循环或复杂函数。
优先队列C++代码
//Priority
#include
// this below code snippet which we have created helps us with making the
// structure for the entities we will be adding to it.
struct item {
int value;
int priority;
// this below small code snippet helps us with storing up the elements
// of the priority queue.
item pr[100000];
// this variable size created by us helps us with pointing to the end index
int size = -1;
// this is one of the most important functions which will help us with
// pushing the elements into the queue priority
void enqueue(int value, int priority)
//to increase the size of the priority variable,e we are
// incrementing it.
size++;
// this below couple of code snippets will helps us with insertion
pr[size].value = value;
pr[size].priority = priority;
// this is another function named peek, which will help us with checking
// the topmost element in the queue priority
int peek()
int highestPriority = INT_MIN;
int ind = -1;
// Check for the element with
// highest priority using a for loop, which is looping till size
// variable
for (int i = 0; i <= size; i++) {
// If the priority is the same, choose
// the element with the
// highest value
if (highestPriority == pr[i].priority && ind > -1
&& pr[ind].value < pr[i].value) {
highestPriority = pr[i].priority;
ind = i;
else if (highestPriority < pr[i].priority) {
ind = i;
// Return position of the element
return ind;
// Function to remove the element with
// the highest priority
void dequeue()
// Find the position of the element
// with the highest priority
int ind = peek();
// these are the for loop lines code helping us with shifting the
// element position from one index before the index of the element
// which has got the top priority of the queue where it is found
for (int i = ind; i < size; i++) {
pr[i] = pr[i + 1];
// the below small decrement operation helps us with decreasing the
// priority of the queue one by one using the(--) functionality
size--;
// from the below lines of code, we will be dealing with the int main()
// driver code functionality
// these are a few function calls that we have written to insert the
// elements as per the priority which we have set
enqueue(10, 2);
enqueue(14, 4);
enqueue(16, 4);
enqueue(12, 3);
// the below variable is named and helps us with storing the topmost
// element temporarily in the next section of the code, we will be
// performing dequeue and insertion operations
int ind = peek();
cout << pr[ind].value << endl;
// this below code function calling helps us with the dequeue operation
dequeue();
// calling the peek function to check for the element at the top
ind = peek();
dequeue();
ind = peek();
Priority Queue (using LinkedList) C++ code
#include
typedef struct node {
int data;
int priority;
struct node* next;
} Node;
Node* newNode(int d, int p)
Node* temp = (Node*)malloc(sizeof(Node));
temp->data = d;
temp->priority = p;
temp->next = NULL;
return temp;
int peek(Node** head) { return (*head)->data; }
void pop(Node** head)
Node* temp = *head;
(*head) = (*head)->next;
free(temp);
void push(Node** head, int d, int p)
Node* start = (*head);
Node* temp = newNode(d, p);
if ((*head)->priority < p) {
temp->next = *head;
(*head) = temp;
else {
while (start->next != NULL
&& start->next->priority > p) {
start = start->next;
temp->next = start->next;
start->next = temp;
int isEmpty(Node** head) { return (*head) == NULL; }
Node* pq = newNode(4, 1);
push(&pq, 5, 2);
push(&pq, 6, 3);
push(&pq, 7, 0);
while (!isEmpty(&pq)) {
cout << " " << peek(&pq);
pop(&pq);
6 5 47
