C++ STL multimap::emplace_hint() 函数
众所周知,C++ 编程语言具有许多内置函数,帮助我们避免编写冗长的代码。C++ STL 的丰富库中就有一个名为 multimap 的查找函数,它将帮助我们返回一个迭代器,指向或指向包含我们创建的长或短 multimap 中的数据遍历的键的位置。multimap emplaces find 比 multimap emplace 快得多。它使用提示插入关键元素,并且前导不影响要插入的位置。
C++ 代码中的 Multimap
// Here we are writing down the C++ programming language code to
// demonstrate
// the concept of multimap find() in C++ STL(Standard Template Library)
#include
#include
#include
// The main driver code functionality starts from here!
// Here, we are trying to create an initializer container
// which will help us with creating a multimap using C++ STL
multimap gquiz1;
// these insert functions which we have written below help us
// with creating a multimap holding the values inserted below!
gquiz1.insert(pair(1, 40));
gquiz1.insert(pair(2, 30));
gquiz1.insert(pair(3, 60));
gquiz1.insert(pair(6, 50));
gquiz1.insert(pair(6, 10));
// elements that we are going to display on the Output screen are
multimap::iterator itr;
cout << "\nThe multimap gquiz1 is : \n";
cout << "\tKEY\tELEMENT\n";
// here we are writing the for loop, which contains the auto code
// functionality containing the find() function at different positions
for (itr = gquiz1.begin(); itr != gquiz1.end(); ++itr) {
cout << '\t' << itr->first
<< '\t' << itr->second << '\n';
cout << endl;
// here, we are trying to add elements randomly,
// as it helps us to check the sorted keys property in C++ STL
gquiz1.insert(pair(4, 50));
gquiz1.insert(pair(5, 10));
// the below code helps us with printing multimap gquiz1 again
cout << "\nmultimap quiz1 after"
<< " adding the extra elements is: \n";
cout << "\tkey\telement\n";
cout << endl;
// the below code snippet below assigning the elements from quiz1 to quiz2
multimap gquiz2(gquiz1.begin(),
gquiz1.end());
// the below code snippet prints all the elements of the multimap gquiz2
cout << "\nThe multimap gquiz2 after"
<< " assign from gquiz1 is : \n";
for (itr = gquiz2.begin(); itr != gquiz2.end(); ++itr) {
cout << endl;
KEY ELEMENT
1 40
2 30
3 60
6 50
6 10
Multimap quiz1 after adding the extra elements is :
key element
1 40
2 30
3 60
4 50
5 10
6 50
6 10
The multimap gquiz2 after assign from gquiz1 is :
KEY ELEMENT
1 40
2 30
3 60
4 50
5 10
6 50
6 10
multimap::emplace_hint()函数在C++ STL中的应用
multimap_name.emplace_hint(position, key, element)
C++代码
// demonstrate
// the concept of multimap::emplace_hint() function in the
// C++ STL(Standard Template Library)
#include
// the main driver code functionality starts from here
multimap mp;
// these emplace functions which we have written below help us
mp.emplace_hint(mp.begin(), 12, 230); // this is faster
mp.emplace_hint(mp.begin(), 14, 440); // this is faster
mp.emplace_hint(mp.begin(), 42, 960); // this is slower
mp.emplace_hint(mp.begin(), 32, 620); // this is slower
mp.emplace_hint(mp.begin(), 31, 540); // this is faster
mp.emplace_hint(mp.begin(), 17, 150); // this is faster
cout << "\nThe multimap is : \n";
cout << "KEY\tELEMENT\n";
for (auto itr = mp.begin(); itr != mp.end(); itr++)
cout << itr->first << "\t" << itr->second << endl;
// The main driver code functionality ends from here!
The multimap is :
KEY ELEMENT
12 230
14 440
17 150
31 540
32 620
42 960
