C++ 预处理器
C++编程语言中主要有四种类型的预处理器指令,它们是:-
- 宏
- 文件包含
- 条件编译
- 其他指令
宏
C/C++编程语言中的宏是最令人兴奋的概念之一。这些是用#define编写的C++代码中的句子,每当调用分配的变量时,关联的值将被交换并执行。
C++代码
// Here we are writing down the simple C++ programming language code snippet
// To demonstrate the concept of C/C++ preprocessors concept with their code
// and relevant display output on the compiler
#include
// macro definition through a simple C++ code with #define functionality
#define LIMIT 15
// the main driver code functionality starts from here
// this is simple for a loop running from 0 initially to the LIMIT
for (int i = 0; i < LIMIT; i++) {
std::cout << i << "\n";
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
C++代码中的带参数宏
// macro with parameter definition
// through a simple C++ code with #define functionality
#define AREA(l, b) (l * b)
int l1 = 310, l2 = 35, area;
area = AREA(l1, l2);
// this is simple output code running whenever the macro with a parameter
// is executed
std::cout << "The area of the object similar to rectangle is: " << area;
The area of the object similar to a rectangle is: 10850
文件包含
这是我们日常使用的常见的C++预处理指令之一,用于包含一些我们日常基本编程需求中必不可少的内置库。
#include
Example:
#include
#include
条件编译
条件编译和保留指令是一种重要且必不可少的指令类型,它们帮助我们根据一些条件来编译和运行程序或代码片段的特定部分,从而无缝地跳过程序中某些特定部分的编译。
#ifdef name_of_your _macro_created
statement 1;
statement 2;
statement 3;
statement 4;
statement 5;
statement 6;
statement 7;
statement n;
#endif
其他指令
除了我们的C++编程语言中的指令之外,还有两个很少被人知道和不太常用的指令 #undef 指令、#pragma startup 和 #pragma exit。它们的实现如下所示
C++ 代码
#include
void function_1_is();
void function_2_is();
#pragma startup function_1_is()
#pragma exit function_2_is()
cout << "Hello coder on javaTpoint.com we are inside the 1st function created now\n";
cout << "Hello coder on javaTpoint.com we are inside the 2nd function created now\n";
cout << "Hello coder on javaTpoint.com we are inside the int main() function now\n";
/tmp/ Lj D4 TT sh NS.o
Hello, coder on javaTpoint.com. We are inside the int primary () function now.
C++ 代码
#include
void __attribute__((constructor)) function_1_is();
void __attribute__((destructor)) function_2_is();
printf("hello coder we are currently inside the function_1_is()\n");
printf("hello coder we are currently inside the function_2_is()\n");
printf("hello coder we are currently inside the int main() function\n");
hello coder, we are currently inside the int main() function
