C++ 友元函数的优缺点
我们已经创建了友元函数来访问C++面向对象编程系统中的不同修饰符,如Protected、Private和Public。友元函数或友元类通常在类之外定义,但仍可以访问类代码中定义的私有、保护和公共成员。
| 优点 | 缺点 |
| 声明可以在代码的任何位置 | 不会传递给派生类 |
| 不需要创建对象来调用它。 | 它们没有存储指定的类。 |
| 可以使用友元函数访问类的非公共成员。 | 当多个类彼此关联时,友元函数非常方便。 |
| 可以添加额外的功能。 | 允许将私有和受保护的成员显示为类的信息。 |
| 使编程体验比以往更高效。 | 在定义了友元函数的同一个类中,可以同时拥有公共、私有和受保护的成员。 |
C++代码
// below, we are writing down the C++ programming language code to
// demonstrate the concept of Advantage and disadvantage friend function C++
// which depicts how the friend function can act as a bridge between classes
#include
// the below class declaration is a forward declaration
class JTP;
class XYZ
int x;
public:
void set_data(int a)
x=a;
friend void max(XYZ, JTP);
class JTP {
int y;
public:
y=a;
void max(XYZ t1,JTP t2)
if(t1.x>t2.y)
cout<
/tmp /mB gjSey FC Z.o
3135
C++ 代码
#include
// defining class A from here
class A
int x;
public:
A()
x=3979;
// the below small code snippet is enough to define the
// friend class for our code to demonstrate the usage of class B
friend class B;
// defining class B from here
class B
public:
void display(A &t)
cout<
After performing the operations, the value for X we have got is 3979
C++代码
// and to find the largest of two numbers using the friend function method
#include
class Largest
// declaring the variables a,b and m for performing the operations
int a,b,m;
public:
void set_data();
friend void find_max(Largest);
// writing the void function to take the inputs from the user without
// writing them again and again from the int main function
void Largest::set_data()
// string display to ask the user to give the input
cout<<"Dear User, please enter the value for the variable first no: ";
cin>>a;
cout<<"Dear User, please enter the value for the variable second no: ";
cin>>b;
// function, which calculates the largest among the inputs entered by the
// user
void find_max(Largest t)
if(t.a>t.b)
t.m=t.a;
else
t.m=t.b;
Cout <<"Hey! User, the maximum number among the inputs entered by you is: "<
Dear User, please enter the value for the variable first no: 35
Dear User, please enter the value for the variable second no: 365
Hey! User, the maximum number among the inputs entered by you is: 365
