C++ STL中的Multimap find()函数
我们都知道,C++编程语言有许多内置函数可以帮助我们避免编写冗长的代码。其中一个函数是multimap find函数,它在C++编程语言的丰富库中,即标准模板库(STL)中可用。它将帮助我们返回一个迭代器,该迭代器指向或指向我们创建的长或小的multimap中包含数据遍历的键的位置。假设您具有知道所有基本数据值的不同目标。在这种情况下,您可以参考C++编程语言的丰富库中为我们提供的equal range函数,即标准模板库(STL)。
C++中的Multimap
// Here we are writing down the C++ programming language code to
// demonstrate
// the concept of multimap find() in C++ STL(Standard Template Library)
#include
#include
#include
// The main driver code functionality starts from here!
// Here, we are trying to create an initialiser container
// which will help us with creating a multimap using C++ STL
multimap gquiz1;
// these insert functions which we have written below help us
// with creating a multimap holding the values inserted below!
gquiz1.insert(pair(1, 40));
gquiz1.insert(pair(2, 30));
gquiz1.insert(pair(3, 60));
gquiz1.insert(pair(6, 50));
gquiz1.insert(pair(6, 10));
// elements which we are going to display on the Output screen are
multimap::iterator itr;
cout << "\nThe multimap gquiz1 is : \n";
cout << "\tKEY\tELEMENT\n";
// here we are writing the for loop, which contains the auto code
// functionality containing the find() function at different positions
for (itr = gquiz1.begin(); itr != gquiz1.end(); ++itr) {
cout << '\t' << itr->first
<< '\t' << itr->second << '\n';
cout << endl;
// here, we are trying to add elements randomly,
// as it helps us to check the sorted keys property in C++ STL
gquiz1.insert(pair(4, 50));
gquiz1.insert(pair(5, 10));
// the below code helps us with printing multimap gquiz1 again
cout << "\nmultimap quiz1 after"
<< " adding the extra elements is : \n";
cout << "\tkey\telement\n";
cout << endl;
// the below code snippet below assigning the elements from quiz1 to quiz2
multimap gquiz2(gquiz1.begin(),
gquiz1.end());
// the below code snippet prints all the elements of the multimap gquiz2
cout << "\nThe multimap gquiz2 after"
<< " assign from gquiz1 is : \n";
for (itr = gquiz2.begin(); itr != gquiz2.end(); ++itr) {
cout << endl;
// here, we are trying to remove all elements up to
// key with the value 3 in quiz2
cout << "\n the quiz2 after the removal of"
<< " elements less than key = 3 : \n";
cout << "\t key \t element \n";
gquiz2.erase(gquiz2.begin(), gquiz2.find(3));
// the below code helps us with removing all the elements with key = 4
int num;
num = gquiz2.erase(4);
cout << "\n quiz 2.erase(4) : ";
cout << num << " removed \n";
// new line printing statement the endl statement
cout << endl;
// the lower and upper bounds of the much awaited
// for multimap gquiz1 key = 5
cout << "the quiz1.lower bound (5) : "
<< "\tkey = ";
cout << gquiz1.lower_bound(5)->first << '\t';
cout << "\telement = "
<< gquiz1.lower_bound(5)->second
<< endl;
cout << "the quiz1.upper bound (5): "
<< "\tKEY = ";
cout << gquiz1.upper_bound(5)->first << '\t';
<< gquiz1.upper_bound(5)->second
<< endl;
// The main driver code functionality ends from here!
输出结果:
KEY ELEMENT
1 40
2 30
3 60
6 50
6 10
Multimap quiz1 after adding the extra elements is :
key element
1 40
2 30
3 60
4 50
5 10
6 50
6 10
The multimap gquiz2 after assignment from gquiz1 is :
KEY ELEMENT
1 40
2 30
3 60
4 50
5 10
6 50
6 10
quiz2 after the removal of elements less than key = 3 :
key element
3 60
4 50
5 10
6 50
6 10
quiz 2.erase(4) : 1 removed
key element
3 60
5 10
6 50
6 10
the quiz1.lower bound (5) : key = 5 element = 10
the quiz1.upper bound (5) : KEY = 6 element = 50
iterator multimap_name.find(key)
constant iterator multimap_name.find(key)
C++代码
// Here we are writing down the C++ programming language code to demonstrate
#include
multimap mp;
mp.insert({ 12, 130 });
mp.insert({ 11, 140 });
mp.insert({ 12, 160 });
mp.insert({ 31, 210 });
mp.insert({ 11, 501 });
mp.insert({ 14, 510 });
cout << "The elements from position 3 in multimap are : \n";
cout << "Key\telements : \n";
// functionality containing the find() function at position 3
for (auto itr = mp.find(31); itr != mp.end(); itr++)
cout << itr->first
Key elements :
31 210
