C++ 优先队列中的多重比较
我们知道优先队列具有先进先出的功能,但它的基本实现还附带了一些优先性。在C++标准模板库的优先队列中,我们可以通过简单的C++代码片段和一个容器轻松实现它。在这里,我们将通过带有注释的代码来理解C++优先队列中的多重比较并获得相关输出。
C++代码
// here we are writing down the C++ programming language code
// to demonstrate the concept of Multiple comparisons in a C++
// priority queue?
#include
// this is the basic template to implement the priority queue
// written as void function without any return type as i
// general, it prints the heap, again and again, any data type
template
void printQueue(T& q)
// simple while loop to implement the priority queue
while (q.empty() == false) {
cout << q.top() << " ";
q.pop();
cout << endl;
// this is the basic priority queue property to sort in the
// form of smallest to highest to the queue
void samplepriorityqueue()
priority_queue, greater > pq;
for (int i = 1; i < 13; i++) {
pq.push(i);
printQueue(pq);
// Here we are using the lambda comparator function
// to sort given priority queue in ascending order
void samplepriorityqueue1()
auto compare = [](int left, int right) {
return left < right;
priority_queue, decltype(compare)> pq(
compare);
pq.push(i);
printQueue(pq);
// the struct keyword helps us with implementing the mycmp
// sorting the priority queue, this function has a flexibility
// extend to various useful features
struct mycmp {
bool operator()(int a, int b)
return a > b;
// below void function is the simple code snippet to implement
// the priority queue number two
void samplepriorityqueue2()
priority_queue, mycmp> pq;
// simple for the loop code snippet to run the loop pushing
// the elements to the priority queue
PQ.push(i);
printQueue(pq);
// The main driver code functionality starts from here
// the driver contains nothing but only function calls
// which implements the priority queue and prints the
// output on our display screens
samplepriorityqueue();
samplepriorityqueue1();
samplepriorityqueue2();
1 2 3 4 5 6 7 8 9 10 11 12
12 11 10 9 8 7 6 5 4 3 2 1
C++代码
// here we are writing down the c++ programming language code
// priority queue?
#include
// Structure of a user-defined data structure
struct jobs {
public:
int priority;
int processing;
int arrival time;
int proccessing_time;
string job;
jobs(int priority1, int processing1, int arrivaltime1,
int proccessing_time1, string s1)
this->priority = priority1;
this->processing = processing1;
this->arrivaltime = arrivaltime1;
this->proccessing_time = proccessing_time1;
this->job = s1;
// to tackle the processing time, we sort the priority queue
// let us say if the priority queue is similar and we have sorted
// it in order of increasing to decreasing in the case of the same
// priority if that is not the case, we have to sort it in the
// ascending order depending on the priority thrown at us!
struct compare {
bool operator()(jobs a, jobs b)
if (a.priority == b.priority) {
return a.processing < b.processing;
return a.priority > b.priority;
priority_queue, compare> pq;
// simple for loop to implement the priority queue named jobs
for (int i = 0; i < 10; i++) {
jobs a(rand() % 11, i + 1, rand() % 3 + i,
rand() % 5 + 3, "my_work_day_job_is" + to_string(i));
PQ.push(a);
while (pq.empty() == false) {
jobs b = PQ.top();
PQ.pop();
// the driver contains the while loop
cout << b.priority << " " << b.processing << " "
<< b.arrivaltime << " " << b.proccessing_time
<< " " << b.job << endl;
0 9 10 5 my_work_day_job_is8
0 8 7 6 my_work_day_job_is7
3 3 2 4 my_work_day_job_is2
4 2 3 3 my_work_day_job_is1
6 1 1 6 my_work_day_job_is0
7 5 5 3 my_work_day_job_is4
7 4 5 4 my_work_day_job_is3
10 10 10 6 my_work_day_job_is9
10 7 7 5 my_work_day_job_is6
10 6 5 4 my_work_day_job_is5
