C++ Timsort算法的实现
Timsort算法采用了两种著名的排序技术,插入排序和归并排序算法。
Timsort的实现非常简单,我们将整个输入数组分割成我们称之为“runs”的块。这些runs的创建是为了更容易实现这两种排序技术。使用插入排序算法对runs进行排序。排序后,使用归并排序中可用的组合函数将它们合并起来。
C++代码
//Here, we are writing down the C++ programming language code to demonstrate
//the concept of Timsort Implementation Using C++ with its output
#include
const int RUN = 32;
// This function sorts the array from the left index to
// to the right index, which is of size almost RUN
void insertionSort(int arr[], int left, int right)
for (int i = left + 1; i <= right; i++)
int temp = arr[i];
int j = i - 1;
while (j >= left && arr[j] > temp)
arr[j+1] = arr[j];
j--;
arr[j+1] = temp;
// this is the function we are writing to merge the sorted RUNS
void merge(int arr[], int l, int m, int r)
// the original array, which is like the input to our code
// is broken into left and right arrays (two parts easy for comparison)
int len1 = m - l + 1, len2 = r - m;
int left[len1], right[len2];
for (int i = 0; i < len1; i++)
left[i] = arr[l + i];
for (int i = 0; i < len2; i++)
right[i] = arr[m + 1 + i];
int i = 0;
int j = 0;
int k = l;
// once the comparison part is done, we have to merge the two arrays
// into a single large sub-array
while (i < len1 && j < len2)
if (left[i] <= right[j])
arr[k] = left[i];
i++;
else
arr[k] = right[j];
j++;
k++;
// the below while loop copies the elements which are present to the
// left (if any)
while (i < len1)
arr[k] = left[i];
k++;
i++;
// right (if any)
while (j < len2)
arr[k] = right[j];
k++;
j++;
// below function code snippet implements the timsort algorithm
//, a combination of both insertion and merge sort algos.
void tim_Sort_(int arr[], int n)
// Sort individual subarrays of size RUN
// below for loop which we have created sorts the sub-arrays which are
// made individually of the size RUN
for (int i = 0; i < n; i+=RUN)
insertionSort(arr, i, min((i+RUN-1),
(n-1)));
// the runs which we have created from size 32 will merge to form
// the size of nearly 64 to 128 and 256, and it goes on ...
for (int size = RUN; size < n;
size = 2*size)
// picking the starting of the left sub-array
// then it will be increased by two (*2)
for (int left = 0; left < n;
left += 2*size)
// below are small code snippets to help us with
// rearrangement of the left and right sub-array indices from
// starting and ending
int mid = left + size - 1;
int right = min((left + 2*size - 1),
(n-1));
// below code helps us with the recombining of the runs using
// the merge sort functionality
if(mid < right)
merge(arr, left, mid, right);
// below function prints the array created
void print_Array_(int arr[], int n)
for (int i = 0; i < n; i++)
printf("%d ", arr[i]);
printf("\n");
// below, we are writing down the drive code for timsort
int arr[] = {-12, 17, 15, -14, 0, 15, 0, 17, -17,
-14, -13, 15, 18, -14, 12};
int n = sizeof(arr)/sizeof(arr[0]);
printf("the given array as input is : \n");
print_Array_(arr, n);
// calling the timsort function to perform its task
tim_Sort_(arr, n);
printf("Array after implementing the sorting : \n");
-12 17 15 -14 0 15 0 17 -17 -14 -13 15 18 -14 12
-17 -14 -14 -14 -13 -12 0 0 12 15 15 15 17 17 18
