在Python中使用给定的复根生成Chebyshev级数
要生成具有给定根的Chebyshev级数,在Python Numpy中使用chebyshev.chebfromroots()方法。该方法返回一个一维系数数组。如果所有根都是实数,则输出是一个实数组;如果某些根是复数,则输出是一个复数数组,即使结果中的所有系数都是实数。参数roots是包含根的序列。
首先,导入所需的库−
from numpy.polynomial import chebyshev as C
给定复数根−
j = complex(0,1)
生成序列 −
print("Result...\n",C.chebfromroots((-j, j)))
获取数据类型 –
print("\nType...\n",C.chebfromroots((-j, j)).dtype)
获取形状−
print("\nShape...\n",C.chebfromroots((-j, j)).shape)
# To generate a Chebyshev series with given roots, use the chebyshev.chebfromroots() method in Python Numpy.
# The method returns 1-D array of coefficients. If all roots are real then out is a real array, if some of the roots are complex, then out is complex even if all the coefficients in the result are real.
# The parameter roots are the sequence containing the roots.
j = complex(0,1)
# Get the datatype
# Get the shape
Result...
[1.5+0.j 0. +0.j 0.5+0.j]
Type...
complex128
Shape...
(3,)
