使用Python生成具有给定复根的埃尔米特级数
要生成具有给定复根的埃尔米特级数,请使用Python Numpy中的hermite.hermfromroots()方法。该方法返回一个一维系数数组。如果所有根是实根,则输出数组是实数数组,如果一些根是复数,则输出是复数,即使结果中所有系数都是实数。参数roots是包含根的序列。
首先,导入所需的库−
要生成具有给定复根的 Hermite 级数,请使用 hermite.hermfromroots() 方法 −
j = complex(0,1)
print("Result...\n",H.hermfromroots((-j, j)))
获取数据类型-
print("\nType...\n",H.hermfromroots((-j, j)).dtype)
获取形状−
print("\nShape...\n",H.hermfromroots((-j, j)).shape)
# To generate a Hermite series with given complex roots, use the hermite.hermfromroots() method in Python Numpy.
# The method returns a 1-D array of coefficients. If all roots are real then out is a real array, if some of the roots are complex, then out is complex even if all the coefficients in the result are real.
# The parameter roots are the sequence containing the roots.
j = complex(0,1)
# Get the datatype
# Get the shape
Result...
[1.5 +0.j 0. +0.j 0.25+0.j]
Type...
complex128
Shape...
(3,)
