在Python中生成Hermite_e多项式和x、y、z样本点的伪Vandermonde矩阵
使用Python的NumPy库中的hermite.hermevander3d()方法,可以得到Hermite_e多项式和x、y、z样本点的伪Vandermonde矩阵。该方法返回伪Vandermonde矩阵。参数x、y、z是具有相同形状的坐标点数组。元素的数据类型将转换为float64或complex128,具体取决于是否存在复数元素。标量将被转换为1-D数组。参数deg是形式为[x_deg、y_deg、z_deg]的最大度数列表。
首先,导入所需的库:
使用numpy.array()方法创建具有相同形状的点坐标的数组 –
x = np.array([1, 2])
y = np.array([3, 4])
z = np.array([5, 6])
显示数组 –
print("Array1...\n",x)
print("\nArray2...\n",y)
print("\nArray3...\n",z)
显示数据类型−
print("\nArray1 datatype...\n",x.dtype)
print("\nArray2 datatype...\n",y.dtype)
print("\nArray3 datatype...\n",z.dtype)
检查两个数组的维度 –
print("\nDimensions of Array1...\n",x.ndim)
print("\nDimensions of Array2...\n",y.ndim)
print("\nDimensions of Array3...\n",z.ndim)
检查两个数组的形状 −
print("\nShape of Array1...\n",x.shape)
print("\nShape of Array2...\n",y.shape)
print("\nShape of Array3...\n",z.shape)
要生成Hermite_e多项式和x、y、z样本点的伪Vandermonde矩阵, 可以使用Python Numpy中的hermite.hermevander3d()函数。
x_deg, y_deg, z_deg = 2, 3, 4
print("\nResult...\n",H.hermevander3d(x,y,z, [x_deg, y_deg, z_deg]))
# Create arrays of point coordinates, all of the same shape using the numpy.array() method
# Display the arrays
# Display the datatype
# Check the Dimensions of both the arrays
# Check the Shape of both the arrays
# To generate a pseudo Vandermonde matrix of the Hermite_e polynomial and x, y, z sample points, use the hermite.hermevander3d() in Python Numpy
Array1...
[1 2]
Array2...
[3 4]
Array3...
[5 6]
Array1 datatype...
int64
Array2 datatype...
int64
Array3 datatype...
int64
1
1
1
Shape of Array1...
(2,)
Shape of Array2...
(2,)
Shape of Array3...
(2,)
Result...
[[1.00000e+00 5.00000e+00 2.40000e+01 1.10000e+02 4.78000e+02 3.00000e+00
1.50000e+01 7.20000e+01 3.30000e+02 1.43400e+03 8.00000e+00 4.00000e+01
1.92000e+02 8.80000e+02 3.82400e+03 1.80000e+01 9.00000e+01 4.32000e+02
1.98000e+03 8.60400e+03 1.00000e+00 5.00000e+00 2.40000e+01 1.10000e+02
4.78000e+02 3.00000e+00 1.50000e+01 7.20000e+01 3.30000e+02 1.43400e+03
8.00000e+00 4.00000e+01 1.92000e+02 8.80000e+02 3.82400e+03 1.80000e+01
9.00000e+01 4.32000e+02 1.98000e+03 8.60400e+03 0.00000e+00 0.00000e+00
0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00
0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00]
[1.00000e+00 6.00000e+00 3.50000e+01 1.98000e+02 1.08300e+03 4.00000e+00
2.40000e+01 1.40000e+02 7.92000e+02 4.33200e+03 1.50000e+01 9.00000e+01
5.25000e+02 2.97000e+03 1.62450e+04 5.20000e+01 3.12000e+02 1.82000e+03
1.02960e+04 5.63160e+04 2.00000e+00 1.20000e+01 7.00000e+01 3.96000e+02
2.16600e+03 8.00000e+00 4.80000e+01 2.80000e+02 1.58400e+03 8.66400e+03
3.00000e+01 1.80000e+02 1.05000e+03 5.94000e+03 3.24900e+04 1.04000e+02
6.24000e+02 3.64000e+03 2.05920e+04 1.12632e+05 3.00000e+00 1.80000e+01
1.05000e+02 5.94000e+02 3.24900e+03 1.20000e+01 7.20000e+01 4.20000e+02
2.37600e+03 1.29960e+04 4.50000e+01 2.70000e+02 1.57500e+03 8.91000e+03
4.87350e+04 1.56000e+02 9.36000e+02 5.46000e+03 3.08880e+04 1.68948e+05]]
