Python 使用集合在三个列表中找到共同的元素
在本文中,我们将学习如何在三个列表中找到共同的元素。列表是Python中最灵活的数据类型,可以用方括号括起来的逗号分隔的值(项)表示。列表的重要特点是列表中的项不需要是相同的类型。然而,集合是Python中的一种集合,它是无序、不可更改和不可索引的。
假设我们有以下输入−
a = [5, 10, 15, 20, 25]
b = [2, 5, 6, 7, 10, 15, 18, 20]
c = [10, 20, 30, 40, 50, 60]
以下应该是显示常见元素的输出:
[10, 20]
使用交集操作符在三个列表中找到共同的元素
在Python中使用交集操作符来找到三个列表中的共同元素−
def IntersectionFunc(myArr1, myArr2, myArr3):
s1 = set(myArr1)
s2 = set(myArr2)
s3 = set(myArr3)
# Intersection
set1 = s1.intersection(s2)
output_set = set1.intersection(s3)
# Output set set to list
endList = list(output_set)
print(endList)
# Driver Code
if __name__ == '__main__' :
# Elements of 3 arrays
myArr1 = [5, 10, 15, 20, 25]
myArr2 = [2, 5, 6, 7, 10, 15, 18, 20]
myArr3 = [10, 20, 30, 40, 50, 60]
# Calling Function
[10, 20]
使用set()方法在三个列表中查找公共元素
要查找三个列表中的公共元素,我们可以使用set()方法 –
print("First = ",myArr1)
print("Second = ",myArr2)
print("Third = ",myArr3)
# Finding common elements using set
output_set = set(myArr1) & set(myArr2) & set(myArr3);
# Converting the output into a list
final_list = list(output_set)
print("Common elements = ",final_list)
First = [5, 10, 15, 20, 25]
Second = [2, 5, 6, 7, 10, 15, 18, 20]
Third = [10, 20, 30, 40, 50, 60]
Common elements = [10, 20]
找到三个列表中的公共元素,使用集合通过用户输入
我们也可以通过使用用户输入来找到三个列表中的公共元素−
def common_ele(my_A, my_B, my_C):
my_s1 = set(my_A)
my_s2 = set(my_B)
my_s3 = set(my_C)
my_set1 = my_s1.intersection(my_s2)
output_set = my_set1.intersection(my_s3)
output_list = list(output_set)
print(output_list)
# First List
A=list()
n=int(input("Enter the size of the List"))
print("Enter the number")
for i in range(int(n)):
p=int(input("Size="))
A.append(int(p))
print (A)
# Second List
B=list()
n1=int(input("Enter the size of the List"))
for i in range(int(n1)):
B.append(int(p))
print (B)
# Third Array
C=list()
n2=int(input("Enter the size of the List"))
for i in range(int(n2)):
C.append(int(p))
print (C)
# Calling Function
common_ele(A, B, C)
Enter the size of the List 3
Enter the number
Size= 2
[2]
Size= 1
[2, 1]
Size= 2
[2, 1, 2]
Enter the number
Size= 2
[2]
Size= 1
[2, 1]
Size= 4
[2, 1, 4]
Enter the size of the List 4
Enter the number
Size= 3
[3]
Size= 2
[3, 2]
[2]
Size= 1
[3, 2, 1]
[1, 2]
Size= 3
[3, 2, 1, 3]
[1, 2]
