Python 如何将字符串转换为数字
要将字符串转换为数字,有多种方法可以使用。让我们一一看看。
使用int()将字符串转换为数字
在这个示例中,我们将使用int()方法将字符串转换为数字 –
# String to be converted
myStr = "200"
# Display the string and it's type
print("String = ",myStr)
print("Type= ", type(myStr))
# Convert the string to integer using int() and display the type
myInt = int(myStr)
print("\nInteger = ", myInt)
print("Type = ", type(myInt))
String = 200
Type= <class 'str'>
Integer = 200
Type = <class 'int'>
使用float()将字符串转换为数字
在这个示例中,我们将使用float()方法将字符串转换为浮点数,然后使用int()方法将浮点数转换为整数 –
myStr = "500"
# Convert the string to float
myFloat = float(myStr)
print("\nFloat = ", myFloat)
print("Type = ", type(myFloat))
# Convert the float to int
myInt = int(myFloat)
String = 500
Type= <class 'str'>
Float = 500.0
Type = <class 'float'>
Integer = 500
将字符串转换为十进制和八进制数
在这个示例中,我们将使用带有基数参数的int()函数将字符串转换为数字。
myStr = "500"
myInt1 = int(myStr)
print("\nInteger (base10) = ", myInt1)
print("Type = ", type(myInt1))
myInt2 = int(myStr, base=8)
print("\nInteger (base8) = ", myInt2)
print("Type = ", type(myInt2))
String = 500
Type= <class 'str'>
Integer (base10) = 500
Integer (base8) = 320
