Selenium 无法将内容提供给iframe中的input字段
问题描述
我尝试使用以下代码向网站上的一个输入字段提供值:
from selenium import webdriver
from selenium.webdriver.chrome.options import Options
from selenium.webdriver.chrome.service import Service
from selenium.webdriver.support.ui import WebDriverWait
from selenium.webdriver.support import expected_conditions as EC
from selenium.webdriver.common.by import By
if __name__ == '__main__':
checkLink = "https://www.skatteetaten.no/person/avgifter/bil/eksportere/regn-ut/"
os.environ['WDM_LOG'] = '0'
options = Options()
options.add_argument("start-maximized")
options.add_experimental_option("prefs", {"profile.default_content_setting_values.notifications": 1})
options.add_experimental_option("excludeSwitches", ["enable-automation"])
options.add_experimental_option('excludeSwitches', ['enable-logging'])
options.add_experimental_option('useAutomationExtension', False)
options.add_argument('--disable-blink-features=AutomationControlled')
srv=Service()
driver = webdriver.Chrome (service=srv, options=options)
waitWD = WebDriverWait (driver, 10)
driver.get (checkLink)
waitWD.until(EC.presence_of_element_located((By.XPATH,'//input[@id="Regnummer"]'))).send_keys("xyz")
driver.quit()
但是我总是遇到TimeoutException异常:
$ python test.py
File "G:\DEV\Fiverr\TRY\csgoenterprise\test.py", line 29, in <module>
File "G:\DEV\.venv\selenium\lib\site-packages\selenium\webdriver\support\wait.py", line 95, in until
raise TimeoutException(message, screen, stacktrace)
selenium.common.exceptions.TimeoutException: Message:
Stacktrace:
如何在此输入框中输入值?
解决方案
你的元素位于具有id iFrameResizer0 的iframe中,因此要在输入框中输入内容,你需要先切换到iframe的上下文。
driver.get("https://www.skatteetaten.no/person/avgifter/bil/eksportere/regn-ut/")
driver.maximize_window()
waitWD = WebDriverWait(driver, 10)
waitWD.until(EC.frame_to_be_available_and_switch_to_it((By.ID, 'iFrameResizer0')))
input_field = waitWD.until(EC.presence_of_element_located((By.XPATH, '//input[@id="Regnummer"]'))).send_keys('xyz')
# switch back if you don't need to be left in iframe context
driver.switch_to.default_content()
