Python 打印句子中ASCII值最高和最低的字符的单词
ASCII(美国信息交换标准代码)是一种字符编码系统,它将每个字符表示为唯一的7位二进制代码,即ASCII值是字符的数值表示。 ASCII值是从0到127的7位二进制代码的范围。例如,空格字符的ASCII代码是32,数字’1’的ASCII代码是49,同样,每个字符都被分配了表示在ASCII表中的ASCII代码。
在Python中,可以使用预定义函数ord()来计算一个字符的ASCII码,它接受一个字符作为输入,并返回该字符的ASCII码。
例如,ord(‘A’)返回65。
问题陈述
给定一个字符串S。打印具有其字符的ASCII值的平均值最高和最低的单词。
输入
S = “today is a sunny day”
Highest ASCII value = “sunny”
Lowest ASCII value = “a”
解释
Average of ASCII values:
today = (116 + 111 + 100 + 97 + 121) / 5 = 109
is = (105 + 115) / 2 = 110
a = 97 / 1 = 97
sunny = (115 + 117 + 110 + 110 + 121) / 5 = 114.6
day = (100 + 97 + 121) / 3 = 106
Thus, “sunny” has the highest average and “a” has the lowest average.
输入
S = “pink city”
输出结果
Highest ASCII value = “city”
Lowest ASCII value = “pink”
解释
Explanation:
pink = (112 + 105 + 110 + 107) / 4 = 108.5
city = (99 + 105 + 116 + 121) / 4 = 110.25
Thus, “city” has the highest average and “pink” has the lowest average.
方法1:蛮力方法
该问题的蛮力解决方法是将输入的句子分割成单词,然后计算每个单词的ASCII值的平均值以找到字符的ASCII值的最高和最低平均值。
将输入字符串转换为单词列表,我们使用内置的split()函数。
伪代码
procedure ascii_avg (word)
sum = 0
For each character c in word
sum = sum + ord(c)
end for
avg = sum / length(word)
ans = avg
end procedure
procedure highLow (sentence)
words = split sentence by whitespace
high_word = words[0]
low_word = words[0]
high_avg = ascii_avg(words[0])
low_avg = ascii_avg(words[0])
for i = 1 to length(words) - 1
word = words[i]
avg = ascii_avg(word)
if avg > high_avg
high_word = word
high_avg = avg
else if avg < low_avg
low_word = word
low_avg = avg
end if
end for
print "Highest ASCII value:", high_word
print "Lowest ASCII value:", low_word
end procedure
示例:Python实现
在下面的程序中,我们使用了split函数将句子分割成单词。
def ascii_avg(word):
Returns the average ASCII value of a word.
return sum(ord(c) for c in word) / len(word)
def highLow (sentence):
Prints the words with the highest and lowest average ASCII values in a sentence.
words = sentence.split()
high_word, low_word = words[0], words[0]
high_avg, low_avg = ascii_avg(words[0]), ascii_avg(words[0])
for word in words[1:]:
if avg > high_avg:
high_word, high_avg = word, avg
elif avg < low_avg:
low_word, low_avg = word , avg
print("Highest ASCII value:", high_word)
print("Lowest ASCII value:", low_word)
highLow("today is a sunny day")
Highest ASCII value: sunny
Lowest ASCII value: a
方法2:使用堆
另一种解决问题的方法是使用一个堆来维护迄今为止最高和最低的ASCII值。此外,我们还维护一个字典,将单词映射到它们的ASCII值,并使用堆提取最高和最低的值。
伪代码
procedure highLow(sentence)
word_avg = {}
for each word in words
avg = 0
for each character c in word
avg = avg + ord(c)
end for
avg = avg / length(word)
word_avg[word] = avg
end for
high_heap = []
low_heap = []
for word, avg IN word_avg.items()
heapq.heappush(high_heap, (-avg, word))
heapq.heappush(low_heap, (avg, word))
end for
high_word = heapq.heappop(high_heap)[1]
low_word = heapq.heappop(low_heap)[1]
end procedure
示例:Python 实现
在下面的程序中,我们使用堆来跟踪最高和最低的 ASCII 值,并使用字典来映射值.
import heapq
def highLow(sentence):
word_avg = {word: sum(ord(c) for c in word) / len(word) for word in words}
high_heap = [(-avg, word) for word, avg in word_avg.items()]
low_heap = [(avg, word) for word, avg in word_avg.items()]
heapq.heapify(high_heap)
heapq.heapify(low_heap)
方法3:使用内置函数
使用内置函数如ord()来返回一个字符的ASCII值,max()和min()来找到最大和最小值,问题可以解决。
伪代码
high_word = max(words, key=lambda w: sum(ord(c) for c in w) / len(w))
low_word = min(words, key=lambda w: sum(ord(c) for c in w) / len(w))
end procedure
示例:Python实现
在下面的程序中,我们使用内置的Python函数来找出具有最高和最低ASCII值的单词。
# min() and max() are built-in functions
时间复杂度 – O(nlogn)
空间复杂度 – O(n)
方法4:按照词的平均ASCII值对其进行排序
通过按照词的平均ASCII值对其进行排序,我们可以从最后一个元素中找到最大值,并从第一个元素中找到最小值。
伪代码
words_sorted = sort words by key=lambda w: sum(ord(c) for c in w) / len(w)
print "Highest ASCII value:", last word in words_sorted
print "Lowest ASCII value:", first word in words_sorted
end procedure
示例:Python实现
在下面的程序中,我们根据单词的平均ASCII值对其进行排序。
# Sorts the words in ascending order
words_sorted = sorted(words, key=lambda w: sum(ord(c) for c in w) / len(w))
print("Highest ASCII value:", words_sorted[-1])
print("Lowest ASCII value:", words_sorted[0])
时间复杂度- O(nlogn)
空间复杂度- O(n)
总结来说,为了找到具有最高和最低平均ASCII值的单词,我们可以使用上述任何一种方法,其中一些易于理解,但时间复杂度较高为O(n^2),但使用内置函数可以将其降低到O(nlogn)。
