Python 如何检查星座
使用Python检查星座
Python在世界各地的许多应用中被使用。其中一个应用是使用Python语言的Beautifulsoup库来检查当天或隔天的星座。以下是使用Python检查星座的步骤。
安装Beautifulsoup
首先,我们需要在我们的Python工作环境中安装Beautifulsoup库。以下是代码。
pip install bs4
安装beautifulsoup的输出如下:
Collecting bs4
Downloading bs4-0.0.1.tar.gz (1.1 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Installing collected packages: bs4
Successfully installed bs4-0.0.1
Note: you may need to restart the kernel to use updated packages.
导入requests模块
现在我们需要导入requests模块和bs4包。
import requests
from bs4 import BeautifulSoup
定义代码
在这个步骤中,我们需要使用requests和BeautifulSoup来定义用于检查星座的代码。以下是代码:
import requests
zodiac = {"Aries": 1,
"Taurus": 2,
"Gemini": 3,
"Cancer": 4,
"Leo": 5,
"Virgo": 6,
"Libra": 7,
"Scorpio": 8,
"Sagittarius": 9,
'Capricorn': 10,
"Aquarius": 11,
"Pisces": 12}
sign_symbol = input("Enter zodiac sign:")
day = str(input("Enter the day of horoscope that you want to know — today/tomorrow/yesterday"))
result = requests.get(f"https://www.horoscope.com/us/horoscopes/general/horoscope-general-daily-{day}.aspx?sign={zodiac[sign_symbol]}")
b_soup = BeautifulSoup(result.content, 'html.parser')
result = b_soup.find("div", attrs={"class": 'main-horoscope'})
print("The horoscope of the",sign_symbol,"for",result.p.text)
以下是根据指定的星座和日期预测的星座运势的输出。
Enter zodiac sign:Virgo
Enter the day of horoscope that you want to know — today/tomorrow/yesterdaytomorrow
The horoscope of the Virgo for Apr 1, 2023 - Every day is a new start and new chance, Virgo. Don't get upset or angry over past events. Don't dwell on things you can't change. Your whole life can turn around in a day, so start every morning with a positive outlook. As you wash your face in the morning, think of it as a renewal. Clean off the debris from yesterday while welcoming the freshness of a new day.
让我们来看看另一个例子,检查给定星座和定义的日期的星座运势。
def horoscope(sign_symbol,day):
sign_symbol = input("Enter zodiac sign: ")
import requests
zodiac = { "Aries": 1,
"Taurus": 2,
"Gemini": 3,
"Cancer": 4,
"Leo": 5,
"Virgo": 6,
"Libra": 7,
"Scorpio": 8,
"Sagittarius": 9,
'Capricorn': 10,
"Aquarius": 11,
"Pisces": 12}
以下是所定义星座和日期的星座运势的输出结果。
Enter zodiac sign: Gemini
Enter the day of horoscope that you want to know — today/tomorrow/yesterdaytoday
The horoscope of the Gemini for Mar 31, 2023 - Things may come to you more easily than usual today, Gemini. This is a sign that you're on the right path and doing things correctly. Life shouldn't have to be full of stress and heartache. If something isn't flowing smoothly, you should consider taking a new approach toward it. Keep a smile on your face and be respectful of the people around you.
