在Python中使用给定的点坐标生成给定阶数的伪范德蒙德矩阵
要生成给定阶数的伪范德蒙德矩阵,可以使用Python Numpy中的polynomial.polyvander2()方法。此方法返回阶数为deg和样本点(x, y)的伪范德蒙德矩阵。
参数x和y是点坐标的数组,形状都相同。数据类型将根据元素是否为复数而转换为float64或complex128。标量将被转换为1-D数组。参数deg是形如[x_deg, y_deg]的最大阶数的列表。
首先,导入所需的库 −
from numpy.polynomial.polynomial import polyvander2d
使用numpy.array()方法创建具有相同形状的点坐标数组。
x = np.array([0.1, 1.4])
y = np.array([1.7, 2.8])
显示数组 –
print("Array1...\n",x)
print("\nArray2...\n",y)
显示数据类型 −
print("\nArray1 datatype...\n",x.dtype)
print("\nArray2 datatype...\n",y.dtype)
检查两个数组的维度 –
print("\nDimensions of Array1...\n",x.ndim)
print("\nDimensions of Array2...\n",y.ndim)
检查两个数组的形状 –
print("\nShape of Array1...\n",x.shape)
print("\nShape of Array2...\n",y.shape)
使用polynomial.polyvander2()函数可以生成给定次数的伪范德蒙德矩阵。
x_deg, y_deg = 2, 3
print("\nResult...\n",polyvander2d(x,y, [x_deg, y_deg]))
# Create arrays of point coordinates, all of the same shape using the numpy.array() method
# Display the arrays
# Display the datatype
# Check the Dimensions of both the arrays
# Check the Shape of both the arrays
# To generate a Pseudo-Vandermonde matrix of given degree, use the polynomial.polyvander2() in Python Numpy
# The method returns the pseudo-Vandermonde matrix of degrees deg and sample points (x, y).
x_deg, y_deg = 2, 3
Array1...
[0.1 1.4]
Array2...
[1.7 2.8]
Array1 datatype...
float64
Array2 datatype...
float64
1
1
Shape of Array1...
(2,)
Shape of Array2...
(2,)
Result...
[[1.000000e+00 1.700000e+00 2.890000e+00 4.913000e+00 1.000000e-01
1.700000e-01 2.890000e-01 4.913000e-01 1.000000e-02 1.700000e-02
2.890000e-02 4.913000e-02]
[1.000000e+00 2.800000e+00 7.840000e+00 2.195200e+01 1.400000e+00
3.920000e+00 1.097600e+01 3.073280e+01 1.960000e+00 5.488000e+00
1.536640e+01 4.302592e+01]]
