使用Python计算具有不同维度的数组的张量点积
给定两个张量a和b,以及包含两个类似于数组的对象(a_axes, b_axes)的array_like对象,对由a_axes和b_axes指定的轴上的a和b的元素(分量)进行求和。第三个参数可以是一个非负整数类型的标量N;如果是这样的话,a的最后N个维度和b的前N个维度将被求和。
首先,导入所需的库 –
使用array()方法创建具有不同维度的两个numpy数组−
arr1 = np.array(range(1, 9))
arr1.shape = (2, 2, 2)
arr2 = np.array(('p', 'q', 'r', 's'), dtype=object)
arr2.shape = (2, 2)
显示数组 –
print("Array1...\n",arr1)
print("\nArray2...\n",arr2)
检查两个数组的尺寸 –
print("\nDimensions of Array1...\n",arr1.ndim)
print("\nDimensions of Array2...\n",arr2.ndim)
检查两个数组的形状 –
print("\nShape of Array1...\n",arr1.shape)
print("\nShape of Array2...\n",arr2.shape)
要计算具有不同维度的数组的张量点积,可以使用 numpy.tensordot()方法-
print("\nTensor dot product...\n", np.tensordot(arr1, arr2, ((0, 1), (0, 1))))
# Creating two numpy arrays with different dimensions using the array() method
arr2.shape = (2, 2)
# Display the arrays
# Check the Dimensions of both the arrays
# Check the Shape of both the arrays
# To compute the tensor dot product for arrays with different dimensions, use the numpy.tensordot() method in Python
Array1...
[[[1 2]
[3 4]]
[[5 6]
[7 8]]]
Array2...
[['p' 'q']
['r' 's']]
3
2
Shape of Array1...
(2, 2, 2)
Shape of Array2...
(2, 2)
['pqqqrrrrrsssssss' 'ppqqqqrrrrrrssssssss']
