如何在Python中使用Bokeh库绘制饼图
Bokeh是一个用于数据可视化的Python库。它使用HTML和JavaScript语言创建图表,并针对现代网页浏览器提供优雅、简洁的构造方式和高性能的交互功能。
在本教程中,我们将学习如何使用Bokeh库在Python中绘制饼图。虽然Bokeh库本身并没有提供直接绘制饼图的模块,但用户可以使用楔形图元素来创建饼图。
wedge()函数具有以下主要参数:
- 楔形图的 x 和 y 坐标
- 楔形图的 半径
- 楔形图的 起始角度
- 楔形图的 结束角度
要绘制出看起来像饼图的楔形图,用户需要调整楔形图的 x 和 y 坐标以及 半径 参数,并调整 起始角度 和 结束角度 参数。
# First, we will import the required modules
from bokeh.plotting import figure as fig
from bokeh.plotting import output_file as OF
from bokeh.plotting import show
# Create a file for saving the model
OF("JTP.html")
# then, we will instantiate the figure object
graph1 = fig(title = "Pie Chart using Bokeh")
# initiate the center of the pie chart
x = 0
y = 0
# then, we will initiate the radius of the glyphs
radius = 1
# start angle values
start_angle = [0, 1.2, 2.1,
3.3, 5.1]
# end angle values
end_angle = [1.2, 2.1, 3.3,
5.1, 0]
# now, generate the color of the wedges
color1 = ["brown", "grey", "green",
"orange", "red"]
# now, we will plot the graph
graph1.wedge(x, y, radius,
start_angle,
end_angle,
color = color1)
# At last, we will display the graph
show(graph1)
在此示例中,用户将可视化一些数据。数据包含了一家公司在2014-15年投资的领域的详细信息。领域如下:
- 顾客: 5%
- 创新: 1%
- 股份: 2%
- 市场推广: 1%
- 技术: 1%
用户可以将 百分比 转换为 弧度 ,通过使用以下公式找到 起始角度 和 结束角度 的值:
math.radians((percent / 100) * 360)
代码:
import math
OF("JTP.html")
# name of the fields for investment
fields = ["Customers", "Innovation", "Shares", "Marketing", "Technology"]
# % tage weightage of the sectors
percentages = [12.5, 32.1, 21.2, 15.1, 19.1]
# formula for converting percentage into radians
radians1 = [math.radians((percent / 100) * 360) for percent in percentages]
# Generating the start angle values
start_angle = [math.radians(0)]
prev = start_angle[0]
for k in radians1[:-1]:
start_angle.append(k + prev)
prev = k + prev
# generating the end angle values
end_angle = start_angle[1:] + [math.radians(0)]
x = 0
y = 0
radius = 1
color1 = ["pink", "yellow", "lightgreen",
"orange", "red"]
for k in range(len(fields)):
start_angle = start_angle[k],
end_angle = end_angle[k],
color = color1[k],
legend_label = fields[k])
show(graph1)
在本教程中,我们讨论了如何使用Python中的bokeh库绘制数据可视化的饼图。
