Python 执行算术操作程序
算术操作是由计算器执行的,我们可以进行加法、减法、乘法和除法。这个示例展示了基本的算术操作,即:
- 加法
- 减法
- 乘法
- 除法
让我们理解以下示例。
# Simple Python program to understand the arithmetical operator addition
# Here, we are storing the first input numbers in num1
num1 = input('Enter first number: ')
# Here, we are storing the second input numbers in num2
num2 = input('Enter second number: ')
# Here, we are declaring a variable sum to store the result
# Here, we are using the arithmetical operator to add the two numbers
sum = float(num1) + float(num2)
# Here, we are printing the sum of the given two numbers
print('The sum of {0} and {1} is {2}'.format(num1, num2, sum))
Enter first number: 10
Enter second number: 20
The sum of 10 and 20 is 30.0
解释 –
在上述代码中,我们使用input()函数将用户输入作为整数进行了获取。然后,我们对给定的数字进行了算术运算,并使用print语句打印结果。我们使用了format()方法来格式化字符串。
示例1:
# Simple Python program to understand the arithmetical operator subtraction
# Here, we are declaring a variable min to store the result
# Here, we are using the arithmetical operator to subtract the two numbers
min = float(num1) - float(num2)
# Here, we are printing the subtraction of the given two numbers
print('The subtraction of {0} and {1} is {2}'.format(num1, num2, min))
The subtraction of 10 and 20 is -10
例2:
# Simple Python program to understand the arithmetical operator muitiplication
# Here, we are declaring a variable mul to store the result
# Here, we are using the arithmetical operator to multiply the two numbers
Mul = float(num1) * float(num2)
# Here, we are printing the multiplication of the given two numbers
print('The multiplication of {0} and {1} is {2}'.format(num1, num2, mul))
The multiplication of 10 and 20 is 200
示例3:
# Simple Python program to understand the arithmetical operator division
# Here, we are declaring a variable div to store the result
# Here, we are using the arithmetical operator to divide the two numbers
div = float(num1) - float(num2)
# Here, we are printing the division of the given two numbers
print('The division of {0} and {1} is {2}'.format(num1, num2, min))
The division of 10 and 20 is 0.5
