Python 使用递归找出数字的阶乘的程序
阶乘: 一个数字的阶乘指的是从1到该数字的所有整数的乘积。用符号”!”来表示。
例如:5的阶乘表示为5!= 12345 = 120。
查看此示例:
def recur_factorial(n):
if n == 1:
return n
return n*recur_factorial(n-1)
# take input from the user
num = int(input("Enter a number: "))
# check is the number is negative
if num < 0:
print("Sorry, factorial does not exist for negative numbers")
elif num == 0:
print("The factorial of 0 is 1")
print("The factorial of",num,"is",recur_factorial(num))
