Python 制作一个简单的计算器程序
在Python中,我们可以创建一个简单的计算器来执行不同的算术运算,如加法、减法、乘法和除法。
方法:
- 我们可以从选项a、b、c和d中选择所需的操作。
- 我们可以输入两个数,如果…elif…else用于执行特定的操作。
- 我们将使用add()、subtract()、multiply()和divide()函数来计算计算器中的相应操作。
示例:
Please select operation -
a. Add
b. Subtract
c. Multiply
d. Divide
Select operations form a, b, c, d: "c"
Please enter first number: 11
Please enter second number: 4
11 * 4 = 44
代码:用于简单计算器
def add(P, Q):
# This function is used for adding two numbers
return P + Q
def subtract(P, Q):
# This function is used for subtracting two numbers
return P - Q
def multiply(P, Q):
# This function is used for multiplying two numbers
return P * Q
def divide(P, Q):
# This function is used for dividing two numbers
return P / Q
# Now we will take inputs from the user
print ("Please select the operation.")
print ("a. Add")
print ("b. Subtract")
print ("c. Multiply")
print ("d. Divide")
choice = input("Please enter choice (a/ b/ c/ d): ")
num_1 = int (input ("Please enter the first number: "))
num_2 = int (input ("Please enter the second number: "))
if choice == 'a':
print (num_1, " + ", num_2, " = ", add(num_1, num_2))
elif choice == 'b':
print (num_1, " - ", num_2, " = ", subtract(num_1, num_2))
elif choice == 'c':
print (num1, " * ", num2, " = ", multiply(num1, num2))
elif choice == 'd':
print (num_1, " / ", num_2, " = ", divide(num_1, num_2))
print ("This is an invalid input")
情况 – (1):
a. Add
b. Subtract
c. Multiply
d. Divide
Please enter choice (a/ b/ c/ d): d
Please enter the first number: 1
Please enter the second number: 2
1 / 2 = 0.5
案例 – (2):
a. Add
b. Subtract
c. Multiply
d. Divide
Please enter choice (a/ b/ c/ d): b
Please enter the first number: 12
Please enter the second number: 11
12 - 11 = 1
