在Python中的randint()函数
在本教程中,我们将学习Python中的”randint()”函数。
“randint()”是Python中random模块的一个内置函数。random模块用于访问各种函数,如使用randint()函数生成随机数。
首先,我们必须导入Python中的random模块以使用randint()函数。该函数基本上用于创建伪随机性。
语法:
randint(start_range, end_range)
参数:
(start_range, end_range): 两个参数都必须是整数类型的值。
它将返回在范围[start_range, end_range]内的随机整数,包括起始和结束数字。
错误和异常:
ValueError: 当用户传递浮点数作为参数时返回ValueError。
TypeError: 当用户传递除整数值以外的任何值作为参数时返回TypeError。
获得两个正数、两个负数和一个正数和一个负数之间的随机数。
import random as rnd
# First, we will generate the random number between any positive number range
random_1 = rnd.randint(55, 75)
print ("The any random number between 55 and 75 is % s" % (random_1))
# Then, we will generate the random number between two given negative number range
random_2 = rnd.randint(-40, -20)
print ("The any random number between -40 and -20 is % s" % (random_2))
# We will now, generate the random number between a positive number and a negative number range
random_3 = rnd.randint(-20, 20)
print ("The any random number between -20 and 20 is % s" % (random_3))
1#
The any random number between 55 and 75 is 74
The any random number between -40 and -20 is -40
The any random number between -20 and 20 is -12
2#
The any random number between -40 and -20 is -29
The any random number between -20 and 20 is -2
在这个示例中,我们将看到用户在使用randint()函数时如何在Python程序中获得ValueError。
# First, we will import the random module
# If the user passes any floating point values as the parameters in the randint() # function.
random_1 = rnd.randint(2.543, 12.786)
print (random_1)
ValueError Traceback (most recent call last)
in
4 # If the user passes any floating point values as the parameters in the randint() function.
5
----> 6 random_1 = rnd.randint(2.543, 12.786)
7 print(random_1)
c:\users\User Name\appdata\local\programs\python\python39\lib\random.py in randint(self, a, b)
336 """
337
--> 338 return self.randrange(a, b+1)
339
340
c:\users\user name\appdata\local\programs\python\python39\lib\random.py in randrange(self, start, stop, step)
300 istart = int(start)
301 if istart != start:
--> 302 raise ValueError("non-integer arg 1 for randrange()")
303 if stop is None:
304 if istart > 0:
ValueError: non-integer arg 1 for randrange()
在这个示例中,我们将看到用户在使用randint()函数时如何在Python中遇到TypeError的情况。
# If the user passes any string or character value as the parameters in the
# randint() function
random_2 = rnd.randint('String', 'Character')
print (random_2)
TypeError Traceback (most recent call last)
in
4 # If the user passes any string or character value as the parameters in the randint() function
5
----> 6 random_2 = rnd.randint('String', 'Character')
7 print (random_2)
c:\users\user name\appdata\local\programs\python\python39\lib\random.py in randint(self, a, b)
336 """
337
339
340
TypeError: can only concatenate str (not "int") to str
应用
用户可以使用randint()函数来模拟一个幸运抽奖游戏。
假设我们参加了一个幸运抽奖游戏,比如“赌场游戏”。玩家有三次机会猜测1到36之间的数字。如果我们猜对了数字,我们就赢了,否则就输掉了游戏。
示例: 应用程序代码
# First, we will import the randint function
# from the random module in Python
from random import randint as rdt
# We will create a function which can generate a new
# random number everytime the code will execute
def generator_1():
return rdt(1, 36)
# Now, we will create a function which takes the input from the user and returns
# true or false depending whether the
# user has guessed the correct number and wins the lucky draw or not.
def random_guess():
# The calls generator_1() which returns a
# random integer between 1 and 36
random_number_1 = generator_1()
# here, we will define the number of
# guesses the user will get
guess_left_1 = 3
# now, we will set the flag variable for checking
# the win-condition for the user
flag_1 = 0
# Then, we will loop the number of times
# the user will get the chances
while guess_left_1 > 0:
# Here, we will take a input from the user.
guess_1 = int (input ("Please select your number to "
"enter the lucky draw game \n"))
# then, we will check whether the guess of the user
# matched the generated win-condition or not.
if guess_1 == random_number_1:
# Then, we will set the flag as 1 if the user have guessed
# the correct number and then loop will broke
flag_1 = 1
break
# If the guess of the user does not matched
# the win-condition then it will print
print ("You have guessed Wrong Number!!")
# then, we will decrease the number of
# guesses left by 1
guess_left_1 -= 1
# If the condition of winning is satisfied then,
# the function random_guess will return "True"
if flag_1 == 1:
return True
# Otherwise, the function will return "False"
return False
# Driver code
if __name__ == '__main__':
if random_guess() == True:
print ("Congratulation!! You have Won the game.")
else :
print ("Sorry, You have Lost the game!")
1#
Please select your number to enter the lucky draw game
3
2
34
Sorry, you have Lost the game!
2#
14
12
3
在本教程中,我们讨论了Python的random模块中的randint()函数。我们展示了用户在使用randint()函数时可能遇到的错误类型。我们还讨论了如何使用randint()函数来创建一个抽奖游戏应用程序。
