Python seek() 方法
Python seek() 方法用于改变文件句柄的当前位置。文件句柄类似于一个光标,用于定义要在文件中读取或写入的数据的位置。
语法:
fi.seek(offset, from_where), where fi is the file pointer
参数:
Offset: 用于定义向前移动的位置数。
from_where: 用于定义参考点。
注意:Python 中的 seek() 方法不返回任何值。
from_where 参数用于选择参考点。它可以接受三个值:
- 0: 0 值用于将 whence 参数设置为文件开头。
- 1: 1 值用于将 whence 参数设置为文件的当前位置。
- 2: 2 值用于将 whence 参数设置为文件的末尾。
from_where 参数默认设置为 0。因此,在文本模式下,除非偏移量等于 0,否则无法将参考点设置为当前位置或末尾位置。
示例1: (用户需要读取包含以下文本的文本文件:
“This is the sentence I am Writing to show the example of the seek() method working in Python.”
fi = open("text.txt", "r")
# the second parameter of the seek method is by default 0
fi.seek(30)
# now, we will print the current position
print(fi.tell())
print(fi.readline())
fi.close()
30
示例文本文件 –
# let's assuming the text file has following 5 lines
# line 1: This is the sentence I am Writing to show the example of the seek()
# method working in Python.
# line 2: The line no. 2 for showing the second method of writing the seek()
# method is python
# Line 3: the line no. 3 for showing the second method
# Line 4: the line no. 4 for showing the second method
# Line 5: the line no. 5 for showing the second method
示例2:(方法2)
fi = open ("text.txt", "r+")
print ("Name of the file: ", fi.name)
line_1 = fi.readline()
print ("Read Line: %s" % (line_1))
# Again, set the pointer to the beginning
fi.seek (0, 1)
line_2 = fi.readline()
print ("Read Line: %s" % (line_2))
# Close opend file
fi.close()
Name of the file: text.txt
Read Line: This is the sentence I am Writing to show the example of the seek() method working in Python.
Read Line: The line no. 2 for showing the second method of writing the seek() method is python
seek() 方法在打开文件为二进制模式时也可以使用负偏移量。
示例3: (负偏移量)
fi = open ("text.txt", "rb")
# the user is setting the reference point to thirtieth position to the left from
# end
fi.seek (-70, 2)
# now print the current position
print (fi.tell())
# now the user will Convert the binary to string
print (fi.readline().decode('utf-8'))
fi.close()
25
