C++ bitset any()函数
C++ bitset any()函数用于测试bitset中是否至少有一个位被设置。它返回一个布尔值,即true或false。
bool any();
它不接受任何参数。
它返回一个布尔值,可以是0或1。
#include <bitset>
// initialization
bitset<4> b1(string("1100"));
bitset<6> b2(string("000000"));
// function to check if any of
// its bits are set or not
bool result1 = b1.any();
if (result1)
cout<< b1 << " has a minimum of one-bit set"
<<endl;
else
cout<< b1 << " does not have any bits set"
<<endl;
bool result2 = b2.any();
if (result2)
cout<< b2 << " has a minimum of one-bit set"
<<endl;
else
cout<< b2 << " does not have any bits set"
<<endl;
1100 has a minimum of one-bit set
000000 does not have any bits set
#include <bitset>
bitset<4> b2(string("00"));
if (result1)
cout<< b1.count() << " has a minimum of one-bit set"
<<endl;
else
cout<< b1.count() << " does not have any bits set"
<<endl;
if (result2)
cout<< b2.count() << " has a minimum of one-bit set"
<<endl;
else
cout<< b2.count() << " does not have any bits set"
<<endl;
2 has a minimum of one-bit set
