C++ map operator[] 函数
C++ map operator[] 函数用于访问具有给定 键值 的映射中的元素。
它类似于 at() 函数。它们之间的唯一区别是,如果映射中没有访问的键,则at抛出异常,而 operator[ ] 会在映射中插入键值,如果该键已经存在于映射中,则什么都不做。
考虑键值 k ,语法如下:
mapped_type& operator[] (const key_type& k); //until C++ 11
mapped_type& operator[] (const key_type& k); //since C++ 11
mapped_type& operator[] (key_type&& k); //since C++ 11
k :访问映射值的元素的键值。
它返回一个对具有键值的元素的映射值的引用。
让我们看一个简单的访问元素的示例。
#include <map>
map<char, int> m = {
{'a', 1},
{'b', 2},
{'c', 3},
{'d', 4},
{'e', 5},
cout << "Map contains following elements" << endl;
cout << "m['a'] = " << m['a'] << endl;
cout << "m['b'] = " << m['b'] << endl;
cout << "m['c'] = " << m['c'] << endl;
cout << "m['d'] = " << m['d'] << endl;
cout << "m['e'] = " << m['e'] << endl;
m['a'] = 1
m['b'] = 2
m['c'] = 3
m['d'] = 4
m['e'] = 5
在上述示例中,operator[]函数用于访问map的元素。
让我们看一个简单的示例,使用它们的键值添加元素。
#include <string>
#include <map>
int main ()
map<int,string> mymap = {
{ 101, "" },
{ 102, "" },
{ 103, ""} };
mymap[101] = "Java";
mymap[102] = "T";
mymap[103] = "Point";
// prints value associated with key 101, i.e. Java
cout<<mymap[101];
// prints value associated with key 102, i.e T
cout<<mymap[102];
// prints value associated with key 103, i.e Point
cout<<mymap[103];
JavaTPoint
在上面的示例中,operator[]用于在使用关联的键值进行初始化之后添加元素。
让我们看一个简单的示例,来改变与键值相关联的值。
#include <string>
#include <map>
int main ()
{ 100, "Nikita"},
{ 200, "Deep" },
{ 300, "Priya" },
{ 400, "Suman" },
{ 500, "Aman" }};
cout<<"Elements are:" <<endl;
for (auto& x: mymap) {
cout << x.first << ": " << x.second << '\n';
mymap[100] = "Nidhi"; // changes the value associated with key 100 to Nidhi
mymap[300] = "Pinku"; // changes the value associated with key 300 to Pinku
mymap[500] = "Arohi"; // changes the value associated with key 500 to Arohi
cout<<"\nElements after make changes are:" <<endl;
Elements are:
100: Nikita
200: Deep
300: Priya
400: Suman
500: Aman
100: Nidhi
200: Deep
300: Pinku
400: Suman
500: Arohi
在上面的示例中,operator[]函数用于更改与它们的键值相关联的值。
示例4
让我们看一个简单的示例来区分operator[]和at()之间的区别。
#include <string>
#include <map>
int main ()
map<char,string> mp = {
{ 'a',"Java"},
{ 'b', "C++" },
{ 'c', "Python" }};
cout<<endl<<mp['a'];
cout<<endl<<mp['b'];
cout<<endl<<mp['c'];
mp['d'] = "SQL";
/* since there is no key with value 'd' in the map,
it insert a key-value pair in map with key 'd' and value = "SQL" */
cout<<endl<<mp['d'];
try {
mp.at('z');
// since there is no key with value z in the map, it throws an exception
} catch(const out_of_range &e) {
cout<<endl<<"\nOut of Range Exception at "<<e.what();
Java
C++
Python
SQL
Out of Range Exception at map::at
在上面的示例中,当我们使用at()函数时,它会抛出一个out_of_range异常,因为在map中没有键值为z的。而当我们使用operator[]并在键值为d时添加一个元素,由于在map中没有键值为’d’的键,它会在map中插入一个键为’d’,值为”SQL”的键值对。
