C++ set get_allocator()函数
C++ set get_allocator() 函数用于返回分配器对象的副本,该对象有助于构造set容器。
allocator_type get_allocator() const; //until C++ 11
allocator_type get_allocator() const noexcept; //since C++ 11
无
返回与set容器相关联的分配器。
复杂度
常量。
迭代器有效性
不改变。
数据竞争
容器被访问。
同时访问set的元素是安全的。
异常安全性
该函数永远不会抛出异常。
让我们看一个简单的示例:
#include <set>
int main(void) {
set<double> m;
double *p;
p = m.get_allocator().allocate(3);
//size of double is 8
cout << "Allocated size = " << sizeof(*p) * 4 << endl;
Allocated size = 32
让我们看一个简单的示例:
#include <set>
int main ()
set<int> myset;
int * p;
unsigned int i;
// allocate an array of 5 elements using myset's allocator:
p=myset.get_allocator().allocate(5);
// assign some values to array
for (i=0; i<5; i++) p[i]=(i+1)*10;
cout << "The allocated array contains:";
for (i=0; i<5; i++) cout << ' ' << p[i];
cout << '\n';
myset.get_allocator().deallocate(p,5);
The allocated array contains: 10 20 30 40 50
让我们看一个简单的示例来检查分配器是否是可互换的:
#include <set>
int main( )
set <int>::allocator_type s1_Alloc;
set <int>::allocator_type s2_Alloc;
set <double>::allocator_type s3_Alloc;
set <int>::allocator_type s4_Alloc;
// The following lines declare objects
// that use the default allocator.
set <int> s1;
set <int, allocator<int> > s2;
set <double, allocator<double> > s3;
s1_Alloc = s1.get_allocator( );
s2_Alloc = s2.get_allocator( );
s3_Alloc = s3.get_allocator( );
cout << "The number of integers that can be allocated"
<< endl << "before free memory is exhausted: "
<< s2.max_size( ) << "." << endl;
cout << "\nThe number of doubles that can be allocated"
<< s3.max_size( ) << "." << endl;
// The following line creates a set s4
// with the allocator of multiset s1.
set <int> s4( less<int>( ), s1_Alloc );
s4_Alloc = s4.get_allocator( );
// Two allocators are interchangeable if
// storage allocated from each can be
// deallocated by the other
if( s1_Alloc == s4_Alloc )
cout << "\nThe allocators are interchangeable."
<< endl;
else
cout << "\nThe allocators are not interchangeable."
<< endl;
before free memory is exhausted: 461168601842738790.
示例4
让我们看一个简单的示例:
#include <set>
int main ()
set < int > c ;
int * p ;
p = c . get_allocator () . allocate ( 2 );
p [ 0 ] = 42 ;
p [ 1 ] = 43 ;
cout << p [ 0 ] << ", " << p [ 1 ] << endl ;
c . get_allocator () . deallocate ( p , 2 );
42, 43
