C++ Set cbegin()函数
C++ set cbegin() 函数用于返回一个指向set容器中第一个元素的常量迭代器。
const_iterator cbegin() const noexcept; //since C++ 11
const_iterator 是一个指向常量内容的迭代器。
无
它返回一个指向set的第一个元素的const_iterator。
复杂度
常数
迭代器有效性
无变化
数据竞争
正在访问容器
同时访问set的元素是安全的。
异常安全
该成员函数从不抛出异常。
让我们看看cbegin()函数的简单示例:
#include <set>
int main ()
set<string> myset= {"Java", "C++","SQL"};
// show content:
for (auto it = myset.cbegin(); it != myset.cend(); ++it)
cout <<*it << '\n';
C++
Java
SQL
在上面的示例中,cbegin()函数被用来返回一个指向myset集合中第一个元素的常量迭代器。
让我们来看一个简单的示例:
#include <set>
int main( )
set <int> s1;
set <int>::iterator s1_Iter;
set <int>::const_iterator s1_cIter;
s1.insert( 1 );
s1.insert( 2 );
s1.insert( 3 );
s1_Iter = s1.begin( );
cout << "The first element of s1 is " << *s1_Iter << endl;
s1.erase( s1_Iter );
// The following 2 lines would err because the iterator is const
// s1_cIter = s1.begin( );
// s1.erase( s1_cIter );
cout << "The first element of s1 is now " << *s1_cIter << endl;
The first element of s1 is 1
The first element of s1 is now 2
让我们看一个简单的示例,使用while循环迭代set:
#include <set>
#include <string>
set<string> myset = {"Robin","Dolly", "John","Nikita"};
set<string>::const_iterator it; // declare an iterator
it = myset.cbegin(); // assign it to the start of the vector
while (it != myset.cend()) // while it hasn't reach the end
cout << *it<< "\n";
// print the value of the element it points to
++it; // and iterate to the next element
cout << endl;
Dolly
John
Nikita
Robin
在上面的示例中,cbegin()函数被用于返回指向myset集合中第一个元素的迭代器。
示例4
我们来看另一个简单的示例:
#include <string>
#include <set>
int main ()
set<int> number = {400, 350, 465, 290, 410};
cout << "Increasing order: " << '\n';
cout<<"______________________\n";
set<int>::const_iterator cit;
for (cit=number.cbegin(); cit!=number.cend(); ++cit)
cout << *cit<< '\n';
auto low = number.cbegin();
auto high = number.rbegin();
cout << "\nSmallest Number is: "<< *low <<endl;
cout<< "Biggest Number is: "<<*high <<endl;
Increasing order:
290
350
400
410
465
Smallest Number is: 290
Biggest Number is: 465
在以上示例中,cbegin()函数用于返回指向myset集合中第一个元素的迭代器。
