C++ 同时执行if和else语句
if-else语句被设计为计划A备用计划B。如果计划A失败,计划B就会被执行。我们如何使两个条件都起作用?我们在C和C++中解决这个鸡生蛋的问题的技巧是使用goto函数。goto函数将两个条件链接在一起,以便如果一个条件执行,后面的条件也同时执行。
C/C++语言中if-else语句的语法是
if (Boolean expression)
// The above written if condition will get executed only if
// the expression inside the Boolean is true
else
// the expression inside the Boolean of if the condition is false
C代码(if-else)
// Here we are writing down the C programming language code to demonstrate the
// concept of If statement along with its relevant code and output supported
// by syntax wherever necessary to explain the concept of executing both
// if and else statements simultaneously
#include
// The main driver code functionality starts from here
int j = 20;
if (j < 15) {
// printing the true condition of boolean
printf("j variable is smaller than 15");
else {
// printing the false condition of boolean
printf("j variable is greater than 15");
// The main driver code functionality ends from here
C ++ 代码(if-else)
#include
int j = 20;
if (j < 15)
cout << "j variable is smaller than 15";
else
cout << "j variable is greater than 15";
if (condition1)
// the expression inside the condition1 is true
if (condition2)
// the expression inside the condition2 is true
嵌套if-else语句是特殊的条件语句;在这里,条件语句可以是互相独立的,或者嵌套在另一个条件语句内部。嵌套if-else语句可以与嵌套的for循环和嵌套的while循环进行比较。实现嵌套if-else语句在C和C++编程语言中进行讨论。
在C中的嵌套if-else语句
#include
int j = 10;
if (j == 10) {
if (j < 15)
printf("j is smaller than 15\n");
if (j < 12)
printf("j is smaller than 12 too\n");
else
// printing the condition of boolean if above is false
printf("j is greater than 15");
在C++中的嵌套if-else
#include
int j = 10;
if (j == 10) {
if (j < 15)
cout << "j is smaller than 15\n";
if (j < 12)
cout << "j is smaller than 12 too\n";
else
cout << "j is greater than 15";
以下我们将编写代码同时执行if和else语句。为了实现这个任务,我们将使用goto函数,并将它们标记为下一个目标条件语句。它可以是一个else语句,也可以是另一个if语句,即嵌套的if。
C 代码
#include
if (1)
label_1: printf("Hello ");
goto label_2;
else
goto label_1;
label_2: printf("JTP");
Hello JTP
C++ 代码
#include
if (1)
label_1: cout <<"Hello ";
goto label_2;
else
goto label_1;
label_2: cout <<"JTP";
Hello JTP
