C++ 和Java中捕获基类和派生类作为异常
在深入讨论我们的主题之前,让我们了解异常和异常处理是什么。异常是在我们编程过程中发生的错误,通常被视为不希望的错误或为了更好地理解。它们就像在编程过程中造成的障碍,异常处理是处理异常或发生的限制的错误处理机制。
处理异常处理和基类和派生类捕获作为异常的各种方法在C ++和Java编程语言中。
- 在基类和派生类被声明为异常的机制中捕获的情况下,我们必须在显示输出终端上看到所述派生类的catch块出现在我们声明的基类类型之前。
- 上述陈述是有效的,我们甚至可以重新检查,如果我们将基类放在派生类之前,那么我们声明的派生类将永远不会被执行。
算法(在C ++和Java中捕获基类和派生类作为异常)
示例:
begin //code starts from here
declare a class b.
say another class d which inherits class b.
now display an object of class d.
Try: throw derived.
Catch (d derived)
Print "code has been caught in the derived exception".
Catch (B b)
Print "code has been caught in the base exception".
End
C++ 代码
//here, we are writing down the C++ programming language code to
//demonstrate the concept of Catching Base and
//Derived Classes as Exceptions in both C++ and Java languages
#include
class base_ {
class derived_: public base_ {
derived_ d;
//these are some necessary functionalities we may use
try {
//this is the monitored code we use
throw d;
catch (base_ b) {
cout << "OH! Caught Based Exception occured";
catch (derived_ d) {
//note: the catch block we wrote below will never get executed!
cout << "oh! caught in the derived exception...";
getchar();
prog.cpp: In function 'int main()':
prog.cpp:20:5: warning: exception of type 'derived_' will be caught
prog.cpp:17:5: warning: by the earlier handler for 'base_.'
catch (base_ b) {
/ tm p /vLt kM pH G zo.o
OH! Caught Based Exception occurred
C++ 代码
#include
class base_ {};
class derived : public base_ {};
derived d;
try {
throw d;
catch (derived d) {
cout << "the code has been caught in the derived exception";
catch (base_ b) {
cout << "the code has been caught in the base exception";
//this below code snippet is to read out the next possible character
getchar();
/tmp /vL tk MpH Gzo.o
Java代码
//here, we are writing down the Java programming language code to
class base_ extends Exception {
class derived_ extends base_ {
public class Main{
public static void main(String args[])
try {
throw new derived_();
catch (base_ b) {
./Main.java:13: error: exception Derived has already been caught
catch (Derived d) {
1 error
Java代码
class base_b extends Exception {}
class derived_d extends base_b {}
public class Main {
public static void main(String args[]) {
// below, we wrote the try block code snippet
try {
throw new derived_d();
catch(base_b) {
System.out.println("the code has been caught in the base exception");
catch(derived_d) {
System.out.println("the code has been caught in the derived exception");
Main.java:12: error: exception Derived has already been caught
catch(derived_d) { System.out.println("the code has been caught in the derived exception");}
