C++ delete运算符
delete运算符被用来释放在C++语言中程序的运行时使用new运算符、calloc和malloc()函数等动态创建的内存空间。换句话说,delete运算符用于从堆中释放数组和非数组(指针)对象,这些对象是new运算符动态分配到堆内存上的变量。我们可以在程序中使用delete运算符或delete [ ]运算符来删除已释放的空间。delete运算符的返回类型为void,因此它没有返回值。
delete运算符的语法
我们可以使用delete运算符来删除特定的元素或变量,如下所示:
delete pointer_variable;
// delete ptr; It deallocates memory for one element
同样地,我们可以使用delete []运算符删除分配的内存空间块。
delete [ ] pointer_variable;
// delete [] ptr; It deallocate for an array
使用delete运算符释放每个变量的内存位置的程序
让我们考虑一个示例,使用delete运算符从堆内存中删除每个变量的分配内存空间。
Program1.cpp
#include
int main ()
// declaration of variables
int *ptr1, *ptr2, sum;
// allocated memory space using new operator
ptr1 = new int;
ptr2 = new int;
cout << " Enter first number: ";
cin >> *ptr1;
cout << " Enter second number: ";
cin >> *ptr2;
sum = *ptr1 + *ptr2;
cout << " Sum of pointer variables = " << sum;
// delete pointer variables
delete ptr1;
delete ptr2;
Enter first number: 5
Enter second number: 8
Sum of pointer variables = 13
使用delete []运算符删除数组对象的程序
让我们创建一个程序,使用C++中的delete []运算符删除动态创建的数组对象的内存空间。
Program2.cpp
#include
int main ()
int *arr, max_num, i;
cout << " Enter total number of elements to be entered : ";
cin >>max_num;
// use new operator to declare array memory at run time
arr = new int [max_num];
cout << " Enter the numbers: \n";
for (i = 0; i< max_num; i++) // input array from user
cout << " Number " << i+1 << " is ";
cin >> arr[i];
cout <<" Numbers are : ";
for (i = 0; i < max_num; i++)
cout << arr[i] << "\t";
// use delete operator to deallocate dynamic memory
delete [ ] arr;
Enter total number of elements to be entered : 7
Enter the numbers:
Number 1 is 45
Number 2 is 600
Number 3 is 78
Number 4 is 93
Number 5 is 29
Number 6 is 128
Number 7 is 32
Numbers are : 45 600 78 93 29 128 32
使用delete运算符删除空指针的程序
考虑一个使用C++编程语言中的delete运算符删除空指针的程序。
Program3.cpp
#include
int main ()
// initialize the integer pointer as NULL
int *ptr = NULL;
// delete the ptr variable
delete ptr;
cout << " The NULL pointer is deleted.";
使用删除操作符删除有或没有值的指针
让我们考虑一个示例,使用C++中的删除操作符删除一个有或没有值的指针变量。
Program4.cpp
#include
int main ()
// Use new operator to create dynamic memory
int *ptr = new int;
// Use new operator to dynamic memory space for an array
int *ptr2 = new int (10);
cout << " The value of ptr is: "<< *ptr << " \n ";
cout << " The value of ptr2 is: "<< *ptr2 << " \n ";
// use delete keyword to delete the value stored in *ptr and *ptr2
delete ptr;
delete ptr2;
The value of ptr is: 1415071048
The value of ptr2 is: 10
使用malloc函数分配动态内存,然后使用delete运算符删除
让我们考虑一个使用malloc函数创建动态内存并使用delete运算符删除在C++编程语言中分配的内存的示例。
Program6.cpp
#include
int main ()
// create a dynamic memory using malloc() function
char *str = (char *) malloc (sizeof (char));
cout << " Dynamic memory is deleted using the delete operator. " << endl;
delete str; // use delete operator to delete the referencing pointer
删除用户定义数据类型变量的程序
让我们写一个程序来演示使用delete操作符删除用户定义对象。
Program7.cpp
#include
struct Ptr
static void operator delete (void *ptr1, std::size_t sz)
cout << " Custom deletion of size " << sz <
Custom deletion of size 1
Custom deletion of size 24
使用delete操作符删除空指针的程序
让我们创建一个程序,使用C++中的delete操作符释放空指针的内存空间。
Program8.cpp
#include
int main ()
// declare a void pointer
void *str;
cout << " The void pointer is deleted using the delete operator. " <
