Python的继承类型
继承是指某个特定类能够从另一个类中获取或继承属性,并在需要时使用这些属性。继承具有以下特点:
- 这是对现实世界中关系的出色表示。
- 它允许代码重用。它不需要我们重复创建相同的代码。它还允许我们在不修改现有代码的情况下向现有类添加选项。
- 它具有传递性,意味着如果B从另一个类A继承,属于B的所有子类将直接继承自类A。
# Python program for demonstrating inheritance
# Here, we will create the base class or the Parent class
class Child1:
# here, we are apply the Constructor
def __init__(self, name):
self.name = name
# now, we will creat a class To get name
def getName1(self):
return self.name
# Now, we will create a class for checking
#if this person is student or not
def isStudent1(self):
return False
# here, we will create the derived class or the child class
class Student1(Child1):
# if the child is student, it will return true
return True
# Driver code
# An Object of Child
std = Child1("Jackie")
print(std.getName1(), std.isStudent1())
# An Object of Student
std = Student1("johnny")
Jackie False
johnny True
Python中的继承类型
继承类型取决于所涉及的子类和父类的数量。Python中有四种可用的继承类型:
单继承
单继承允许派生类继承一个父类的属性,这样可以重用代码并在现有代码中引入额外的功能。
示例:
# Python program for demonstrating single inheritance
class Parent1:
def func_1(self):
print ("This function is defined inside the parent class.")
# now, we will create the Derived class
class Child1(Parent1):
def func_2(self):
print ("This function is defined inside the child class.")
# Driver's code
object = Child1()
object.func_1()
object.func_2()
多重继承 如果一个类可以由多个基类创建,这种继承被称为多重继承。当存在多重继承时,每个基类中存在的属性都会被传递给派生类。
示例:
# Python program for demonstrating multiple inheritance
# Here, we will create the Base class 1
class Mother1:
mothername1 = ""
def mother1(self):
print(self.mothername1)
# Here, we will create the Base class 2
class Father1:
fathername1 = ""
def father1(self):
print(self.fathername1)
class Son1(Mother1, Father1):
def parents1(self):
print ("Father name is :", self.fathername1)
print ("Mother name is :", self.mothername1)
# Driver's code
s1 = Son1()
s1.fathername1 = "Rajesh"
s1.mothername1 = "Shreya"
s1.parents1()
Father name is : Rajesh
Mother name is : Shreya
多级继承 ,原始类的特征以及由其派生的类的特征都传递给新的类。这类似于一个涉及祖父母和子女之间关系的情况。
示例:
# Python program for demonstrating multilevel inheritance
class Grandfather1:
def __init__(self, grandfathername1):
self.grandfathername1 = grandfathername1
# here, we will create the Intermediate class
class Father1(Grandfather1):
def __init__(self, fathername1, grandfathername1):
self.fathername1 = fathername1
# here, we will invoke the constructor of Grandfather class
Grandfather1.__init__(self, grandfathername1)
# here, we will create the Derived class
class Son1(Father1):
def __init__(self,sonname1, fathername1, grandfathername1):
self.sonname1 = sonname1
# here, we will invoke the constructor of Father class
Father1.__init__(self, fathername1, grandfathername1)
def print_name(self):
print('Grandfather name is :', self.grandfathername1)
print("Father name is :", self.fathername1)
print("Son name is :", self.sonname1)
# Driver code
s1 = Son1('John', 'John Jr', 'John Jr Jr')
print (s1.grandfathername1)
s1.print_name()
John Jr Jr
Grandfather name is : John Jr Jr
Father name is : John Jr
Son name is : John
Hierarchical Inheritance 如果从同一个基类创建了多个派生类,这种继承关系被称为层次继承。在这种情况下,我们有两个基类作为父类,以及两个子类作为派生类。
示例:
# Python program for demonstrating Hierarchical inheritance
class Parent1:
def func_1(self):
# Derived class1
class Child_1(Parent1):
def func_2(self):
print ("This function is defined inside the child 1.")
# Derivied class2
class Child_2(Parent1):
def func_3(self):
print ("This function is defined inside the child 2.")
# Driver's code
object1 = Child_1()
object2 = Child_2()
object1.func_1()
object1.func_2()
object2.func_1()
object2.func_3()
