操作系统 二进制信号量或互斥量
在计数信号量中,没有提供互斥性,因为我们有一组需要同时执行临界区的进程。
然而,二进制信号量严格提供互斥性。在这里,临界区中只能有最多1个进程,而不是多个可用槽位。信号量只能有两个值,0或1。
让我们看看二进制信号量的编程实现。
StructBsemaphore
enum Value(0,1); //value is enumerated data type which can only have two values 0 or 1.
Queue type L;
/* L contains all PCBs corresponding to process
Blocked while processing down operation unsuccessfully.
Down (Bsemaphore S)
if (s.value == 1) // if a slot is available in the
//critical section then let the process enter in the queue.
S.value = 0; // initialize the value to 0 so that no other process can read it as 1.
else
put the process (PCB) in S.L; //if no slot is available
//then let the process wait in the blocked queue.
sleep();
Up (Bsemaphore S)
if (S.L is empty) //an empty blocked processes list implies that no process
//has ever tried to get enter in the critical section.
S.Value =1;
else
Select a process from S.L;
Wakeup(); // if it is not empty then wake the first process of the blocked queue.
