Python 字符串 replace()方法
返回一个字符串的副本,其中所有出现的子字符串old都被new替代。如果给定了可选参数count,那么只会替换第一个count个出现的子字符串。
语法:
replace(old, new[, count])
old: 在这里,该参数用于被替换的旧字符串。
new: 在这里,该参数用于替换旧字符串的新字符串。
count: count 参数用于描述替换操作的次数。
返回字符串。
让我们看一些 replace() 方法的示例,以理解其功能。
# Here, we are creating a simple python program to understand the replace() method # with the examples
# Here, we are creating a Variable and declaration it with some data
str = "Java is a programming language"
# Here, we are calling the function
str2 = str.replace("Java","C")
# Here, we are declaring another variable str2 and storing the string after performing
# replace() method
# Here, we are displaying the result
print("The Old String before performing the replace method is: \n",str)
print("The new String after performing the replace method is: \n",str2)
C is a programming language
str = "Java C C# Java Php Python Java"
# Here, we are calling the function and replacing all the occurrence of the old string
str2 = str.replace("Java","C#")
# replace() method
# Here, we are calling the function and replacing all the first occurrence of the old
# string
str2 = str.replace("Java","C#", 1)
# replace() method
Old String:
C# C C# C# Php Python C#
C# C C# Java Php Python Java
# Simple Python program to understand the replace() method with example
# Variable declaration
str = "Apple is a fruit"
str2 = str.replace(str,"Tomato is also a fruit")
print(str2)
