C++ try/catch
在C++编程中,使用try/catch语句进行异常处理。C++ try块 用于放置可能发生异常的代码。而 catch块 用于处理异常。
没有try/catch的C++示例
float division(int x, int y) {
return (x/y);
int main () {
int i = 50;
int j = 0;
float k = 0;
k = division(i, j);
cout << k << endl;
Floating point exception (core dumped)
C++ try/catch示例
if( y == 0 ) {
throw "Attempted to divide by zero!";
return (x/y);
int main () {
int i = 25;
int j = 0;
float k = 0;
try {
k = division(i, j);
cout << k << endl;
}catch (const char* e) {
cerr << e << endl;
