C++ switch开关语句
C++ 开关语句从多个条件中执行一个语句。它类似于C++中的if-else-if梯形语句。
switch(expression){
case value1:
//code to be executed;
break;
case value2:
break;
default:
//code to be executed if all cases are not matched;
break;
C++ Switch示例
int main () {
int num;
cout<<"Enter a number to check grade:";
cin>>num;
switch (num)
case 10: cout<<"It is 10"; break;
case 20: cout<<"It is 20"; break;
case 30: cout<<"It is 30"; break;
default: cout<<"Not 10, 20 or 30"; break;
Enter a number:
10
It is 10
Enter a number:
55
Not 10, 20 or 30
