C++ 字符串
在 C++ 中,字符串是一个代表字符序列的 std::string 类的对象。我们可以对字符串执行许多操作,例如拼接、比较、转换等等。
C++ 字符串示例
让我们看一下 C++ 字符串的简单示例。
int main( ) {
string s1 = "Hello";
char ch[] = { 'C', '+', '+'};
string s2 = string(ch);
cout<<s1<<endl;
cout<<s2<<endl;
Hello
C++
C++字符串比较示例
让我们看一下使用strcmp()函数进行字符串比较的简单示例。
#include
#include <cstring>
int main ()
char key[] = "mango";
char buffer[50];
do {
cout<<"What is my favourite fruit? ";
cin>>buffer;
} while (strcmp (key,buffer) != 0);
cout<<"Answer is correct!!"<<endl;
What is my favourite fruit? apple
What is my favourite fruit? banana
What is my favourite fruit? mango
Answer is correct!!
C++字符串连接示例
使用strcat()函数的简单示例。
#include <cstring>
char key[25], buffer[25];
cout << "Enter the key string: ";
cin.getline(key, 25);
cout << "Enter the buffer string: ";
cin.getline(buffer, 25);
strcat(key, buffer);
cout << "Key = " << key << endl;
cout << "Buffer = " << buffer<<endl;
Enter the key string: Welcome to
Enter the buffer string: C++ Programming.
Key = Welcome to C++ Programming.
Buffer = C++ Programming.
C++字符串复制示例
让我们来看一个使用strcpy()函数复制字符串的简单示例。
#include <cstring>
strcpy(buffer, key);
cout << "Key = "<< key << endl;
cout << "Buffer = "<< buffer<<endl;
Enter the key string: C++ Tutorial
Key = C++ Tutorial
Buffer = C++ Tutorial
C++字符串长度示例
让我们来看一个简单的示例,使用strlen()函数来找到字符串的长度。
#include <cstring>
char ary[] = "Welcome to C++ Programming";
cout << "Length of String = " << strlen(ary)<<endl;
Length of String = 26
