C++ Math lrint()函数
该函数根据当前的舍入模式将给定的值四舍五入,并返回 long int 类型的值。
假设一个数为 ‘x’,语法如下:
long int lrint(data_type x);
x :可以是浮点数、双精度浮点数或长双精度浮点数的值。
它返回 x 的四舍五入值,返回值的类型是长整型。
让我们看一个简单的示例。
#include
#include
#include
float r;
int str;
cout<<"Enter the value which you want to round :";
std::cin >> r ;
cout<<'\n';
cout<<"Name of the methods are :"<<'\n'<<"1. Rounding downwards"<<'\n'<<"2. Rounding upwards"<<'\n'<<"3.
Rounding towards zero"<<'\n'<<"4. Rounding to the nearest"<<'\n';
cout<<"Enter the number of rounding method :";
cin>>str;
cout<<'\n';
switch(str)
case 1:
fesetround(FE_DOWNWARD);
cout<<"Rounding downwards,value is :"<
Enter the value which you want to round : 7.8
2. Rounding upwards
3. Rounding towards zero
Enter the number of rounding method : 1
Rounding downwards,value is :7
